1998 Ranger 4 wheel drive problems.
Old Feb 6, 2012 | 02:53 PM
ddt4812's Avatar
ddt4812
I have a 98 Ranger 4x4, 3.0L engine. It will not go into 4 wheel drive. After the vehicle starts, the 4HI and 4LO lights flash about 4 times. There is power at the switch, I've put a new motor on at the transfer case but I am still getting no power at the motor. I've checked all the fuses and they are good as well. Can any of you tell me if you have had this problem, or what you think it may be?
Old Feb 8, 2012 | 11:41 AM
ddt4812's Avatar
ddt4812
Bump..... Plz help
Old Feb 9, 2012 | 06:20 PM
joew900's Avatar
joew900
On my old 88 Ranger I had a similar problem and it turned out to be corroded wire in the harness going to motor at the transfer case. I hope this helps as it was by pure chance I found it. Man I really miss that old girl. 219,000 miles when I got rid of it.
Old Feb 9, 2012 | 06:51 PM
Joejoecat's Avatar
Joejoecat
Have you checked your relays ?
Old Feb 9, 2012 | 09:10 PM
cj06's Avatar
cj06
see if this helps !
Transfer Case Troubleshooting - The Ranger Station
Old Feb 9, 2012 | 11:32 PM
ReBilld's Avatar
ReBilld
If it has the harness with the big square plug that goes through the floor, check that plug for corrosion.
Saminy
Jun 10, 2012 08:43 PM
FastBlack
Aug 16, 2008 09:53 PM
Kermit1
Mar 23, 2006 06:02 AM
brewster
Jan 12, 2006 08:09 AM
onepingonly
Dec 29, 2004 02:18 PM
