Battery light on - what to check first?
Old Nov 8, 2011 | 11:45 AM
Bobcat7's Avatar
Bobcat7
I have been working out-of-town and the ol' lady has been driving my truck. I know that's my first problem but...
I started it yesterday and the battery light is on and the volt meter was showing 9 or 10 volts - I am assuming the alternator is not charging.
Is there any other things I should check before ordering a new alt?
I did check the obvious and the belt is there and turning, is there an alternator fuse?
I started just now and the voltmeter started at the N on normal (w a freshly charged batt) and then click, and then just below normal, wts light goes off and I cranked and started, then 20 seconds later the battery light came on and stayed on even after reving a bit.
97 F-350 PSD 140k miles - just stock
Old Nov 8, 2011 | 12:18 PM
stainlessstroker95's Avatar
stainlessstroker95
I would check the wires on the altnator. I had that problem and it was my big positive cable end that hooks to the altnator. It was just about ripped in half. The connection on top of altnator can work itself loose also.
Old Nov 8, 2011 | 12:22 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Smile
First what he said. And check all your connections (battery, starter, relay, etc)
Old Nov 8, 2011 | 12:43 PM
brown435's Avatar
brown435
Sensor wire on alternator gets loose on BOTH our PSD's and goes on .... then goes off based on RPM and road conditions.
Old Nov 8, 2011 | 10:46 PM
MONAVIERONJON's Avatar
MONAVIERONJON
x3 on that alt wire,an easy quick check before getting in depth.
virgil spells
General Diesel Discussion
Sep 7, 2013 12:06 PM
F350-6
33
Sep 4, 2010 02:24 PM
7.3blacksmoke
Feb 9, 2009 08:59 AM
John311t
17
Aug 24, 2007 07:04 PM
Chumbucket
Electrical Systems/Wiring
Aug 8, 2006 03:10 AM
