compression ratio
Old Feb 26, 2003 | 10:33 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
compression ratio
Originally posted by tejomakash
Not mustard gas. Mustard gas raises huge blisters wherever it touches you - skin, eyes, nasal passages, bronchial tubes, lungs. Nasty stuff.
Nasty, nasty stuff.
I know, I was thinking of something else, but couldn't quite put my finger on it. It's been too long since AP Chem.
It's chlorine, I know that, I've had a taste of it myself.
ak
Old Feb 27, 2003 | 06:50 AM
William's Avatar
William
compression ratio
Man did we wander off on this one or what! Poor Jeff must be wondering what happened to his question. So here goes! Clean out the combustion chambers using water. Change the points and set the dwell, or install a Pertronix Ignitor and time the engine at 10 degrees initial advance. Go for a test drive and put the engine under load, if it still pings, back off the timing a couple of degrees at a time until it no longer pings under load. Reading the original post I think this problem has developed over time. So it may be related to the points wearing out?
Old Feb 27, 2003 | 04:36 PM
ford429cu's Avatar
ford429cu
compression ratio
It sounds like cleaning the engine with water works best. I can't remember what the engine is timed at. I don't have points on this engine. It has the duraspark setup out of a 79, and I did the large cap conversion. Not sure if a weak or worn/old dis would be some of the problem? It has a new cap and rotar though, and wires. So with some new parts and a clean combustion chamber should I be able to run 87 octane and not have a pinging problem and still have some power out of this engine?
Jeff
Old Feb 28, 2003 | 07:10 AM
William's Avatar
William
compression ratio
Jeff, I sure hope so. That noise you hear will destroy pistons. Pull a couple of spark plugs and look in the combustion chambers, then clean them really good. The dribbling water hose would be easier than my gallon jug method. Get it up to operating temp and rev it up to about 2000 RPM and slowly dribble the water in. Do this for about 10-15 min. You will need to change oil after this (I usually do this once a year during oil change). After you clean the combustion chambers pull a plug and look again. You should be able to clearly see the piston. Let us know how this turns out.
Old Feb 28, 2003 | 08:02 AM
nevrenufhp's Avatar
nevrenufhp
compression ratio
Maybe I should have the pinging in my Cummins checked...it does it all the time!
Old Feb 28, 2003 | 09:30 AM
67 428 Fairlane Ranchero's Avatar
compression ratio
Try the walnut or the popcorn thing in your Cummins and see if that fix's your problem
jjurva
Dec 19, 2011 10:17 AM
pidaster
Aug 30, 2011 06:43 PM
1978Crew
Oct 9, 2007 08:44 AM
koalamazed
Aerostar
Aug 13, 2004 12:46 AM
WrenchHead84
Mar 10, 2003 08:35 AM
