Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Reload this Page >
Firing order correct, got gas, got spark, timing should be good, why won't it run?
  #31
Old 11-21-2010, 05:38 PM
Mervy49's Avatar
Mervy49
Mervy49 is offline
Mervy49 is a splendid one to beholdMervy49 is a splendid one to beholdMervy49 is a splendid one to beholdMervy49 is a splendid one to beholdMervy49 is a splendid one to beholdMervy49 is a splendid one to beholdMervy49 is a splendid one to behold
The distributor from the 460 should drop right into the 351w. I have a 429 and have exchanged the distributors back and forth between the 351w and 429. As far as I know the 460 and 429 use the same distributor.
  #32
Old 11-21-2010, 07:12 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
The 351C/M/400/429/460 all use the same distributor and are interchangable. I believe the 351W uses the same housing, but has the smaller Windsor gear. If swapping the gears, be sure to check the depth of the gear and that it is meshing correctly with the camshaft.
Edit; You may want to double check that the oil pump drive shaft is the same size. I seem to recall the Cleveland/BB has a larger diameter shaft than the Windsor, so the two distributors wouldn't interchange, even with a gear swap.
  #33
Old 11-21-2010, 09:52 PM
1958fun's Avatar
1958fun
1958fun is offline
1958fun is starting off with a positive reputation.
Just thought I would put my two cents in, did you try bring the number one piston up top and take the cap off the distributor to make sure it is in the correct position? I've had them jump time time like that when the timing belt was worn out.
  #34
Old 11-22-2010, 01:09 AM
Julies Cool F1
Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Are you certain that the rotor in the distributor is making good contact both at the center point and on the outer contacts?
Question????? Do you still have points in this distributor with the Durapsark system? I thought not! I'm wondering why there is a resistor wire in the set up if not.
Also, Im wondering why the redundant ground/black wire between the module and distributor? That shouldn't be necessary either.
  #35
Old 11-22-2010, 11:08 AM
black58's Avatar
black58
black58 is offline
black58 is starting off with a positive reputation.
I just got in from tinkering with it a bit. It's running! I still need to tweak the timing a bit and get the exhaust finished, but it ran and stayed running till I shut it off. The resistor is in the picture only, I'm not using one. I forgot to mention that.
Here's the deal with the no start. I read some time ago that a points style cap and rotor would fit on the non-points style distributor, so I tried it out. When it initially wouldn't start, but was at least trying to, I swapped just the cap back to the HEI style, forgetting that I had swapped the rotor out as well. I was out in the garage, cleaning a bit for the winter and found the box with the HEI rotor still in it. I immediately realized what I had done, and made the switch. Chalk it up to another incident of too much on my mind when I'm working on something, I guess. Thanks for the help guys.
  #36
Old 11-22-2010, 11:43 AM
Julies Cool F1
AHAH!
It may take us awhile, but eventually we will usually figure out what's happening. We might rebuild your truck in the process, but at least it will run! LOL!
I wonder what the coil sparking thing was all about?
ExPACamper
35
01-13-2018 11:37 PM
80'BUB
01-22-2017 04:51 PM
rsm688
08-15-2015 11:22 PM
78ferd
05-01-2015 03:00 AM
jlj6t
15
04-10-2011 05:02 PM
Quick Reply: Firing order correct, got gas, got spark, timing should be good, why won't it run?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
