Aerostar Ford Aerostar
Engine woes on '89
Old Feb 23, 2003 | 12:53 PM
razor_jim's Avatar
razor_jim
Engine woes on '89
My '89 Aerostar's engine is loud, as if though the thing is roaring. Upon further inspection I found that the engine fan has some cracks in it. I'm not sure if that's the cause of the noise. The concern goes further when I'm driving and I try to speed up quickly. The belts in the engine seem to squeal for a second or so when I'm doing this.
Another problem: After doing heavy driving or climbing a hill, the engine seems to smoke after I turn it off. It's a bit of a strange-smelling smoke, it's white and seems to rise up from the engine itself when I take a look. I don't know the cause of this problem either.
If anyone can give some input on what these problems are, that would be great. Thank you.
Old Feb 23, 2003 | 10:17 PM
rickm5's Avatar
rickm5
Talking Engine woes on '89
i'm just a backyard mechanic, but i'd check the fan and clutch assembly. the roaring could be the fan, especially if engine rpms aren't changing. there are some posts outlining how to check for wobble etc to determine if the fan/clutch has gone bad. the cracks in your fan can't be a good thing, but not sure if they alone would cause this.the clutch not working might?..how many miles on the engine? ever chang the fan and clutch assembly before? go to "search" and enter fan or fan clutch. that might get you to some of them
the smoke and different odor could come from a slipping serpintine belt. i had that experience last year, i had a strange rubber/burining smell up front, i checked the belt, it had many cracks in it so i replaced it. no more smell. guess the smoke could be from the same thing? i suspect my power steering pump is getting harder to spin with age, causing the drag on the belt.. not sure. but i'm ok for now.
other things up front would be radiator or hose leak, with antifreeze getting on the block andburning off...that would smell weird..or a tranny fluid coolant line leak at or under the front of the engine. all those thing would bear some crawling around to check... hope that helps some, at least it is somewhere to start.. rick
