Anyone put an AOD in a 57-60 F100? - Ford Truck Enthusiasts Forums
Old 10-08-2010, 09:35 PM
niteowl
niteowl is offline
niteowl is starting off with a positive reputation.
My poor 60 F100 has been sitting in the back yard for the last 5 years and I want to get it back on the road. I am considering a turnkey engine to get things going easy and quick but am not sure what to do about the transmission.
Originally I wanted to put in an AOD but I am not sure of the clearances without a lot of modifications.
I setup mounts for a 302 and put it in place with the existing C4. The engine is very close to the firewall but sits low in the engine compartment so that the lower pulley is below the front crossmember but clears it by 1-2 inches.
I wonder if the larger AOD tranny is going to cause me problems.
How strong is the C4? If I got a rebuilt C4 would it handle a 300HP engine that will not be raced but would of course be passing vehicles on the highway?
I been away from this too long I have forgotten everything I had learned.
Old 10-09-2010, 09:35 PM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
GreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to all
Don't have a Fridge but I did put an AOD in my 49 F-1. There were no firewall or floor modifications so my guess is the AOD wil fit your Fridge just fine. I also think a rebuilt C4 would handle up to 300 HP with no problem so I think you're golden either way....
Old 10-09-2010, 09:48 PM
carnut122's Avatar
carnut122
carnut122 is offline
carnut122 is gaining momentum as a positive member of FTE.carnut122 is gaining momentum as a positive member of FTE.
I have one in my 53 and there are no clearance problems.
Old 10-10-2010, 03:13 PM
niteowl
niteowl is offline
Last I was under the truck looking at the C4 there was very little room available which made me think the AOD might not fit well.
I have a a bolt in crossbar tranny mount from a Crown Victoria that looks like it will fit well under my truck. I have to look and see if possibly I can drop out the crossmember that is in there to make space and reinforce the frame elsewhere or rely on the Crown Vic crossmember to do it.
Old 10-10-2010, 03:24 PM
85e150six4mtod
85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Dimensions here, pretty close it looks like, especially the pan-fill C4 vs. AOD, but then you have to compare all dimensions. A couple inches might as well be a mile if it don't fit.
TCI - TECHNICAL INFORMATION: Transmission Dimensions
ALSO, read their propaganda on the AOD. At the very least, you want an '88 to '93 trans to start with, as earlier models were trouble. Additional beef ups available for ju$t a little more ca$h....
Old 06-13-2013, 11:21 PM
Goeasybaby10
Goeasybaby10 is offline
Goeasybaby10 is starting off with a positive reputation.
Can anyone tell me if the 57 to 60 frame is the same or close to the 53 to 56 ?
Old 03-18-2015, 06:50 PM
bruman
bruman is offline
bruman is starting off with a positive reputation.
Hi!
Bruman here. I dropped an '86 302 W/the AOD into my '60 F1oo W/no problems. It's been in there for years, serving me well!!
Old 03-18-2015, 07:07 PM
TigerDan's Avatar
TigerDan
TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Bruman, welcome to FTE. Just a quick note...when posting to a thread, you might take a quick look at the date in upper left corner of each post. This one is 5 years old and the last post was almost 2 years ago...
Old 03-18-2015, 10:33 PM
bruman
bruman is offline
Wink AOD
Hi TigerDan!
Look in the upper right corner of my post ! However, I did just come back into the fold after a long absence. I must, however, admit it was pretty goofy of me not to check the date of the post before replying! See ya.
1960 F 100
1986 302/
AOD
Old 03-18-2015, 11:13 PM
TigerDan's Avatar
TigerDan
TigerDan is offline
Okay then, welcome back to FTE!
Old 04-01-2015, 12:12 PM
Jason428
Jason428 is offline
Jason428 is starting off with a positive reputation.
I installed a 86 aod and even used the 86 crossmember with slight mods. Fit great in my 58
harleymsn
74
12-18-2016 10:15 AM
A73F100
01-14-2014 08:50 PM
hooler1
08-13-2013 01:49 PM
Milwaukee1979F150
11-23-2009 06:58 PM
88blackgt
07-11-2009 02:30 AM
Quick Reply: Anyone put an AOD in a 57-60 F100?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
