Ordering 2011 EcoBoost
What did the dealer have to say about it? I think it's stupid myself. If you tow you need the larger tank
The Ecoboost is designed to operate much like a diesel but on gasoline. (high compression, direct injection, etc) I think your styatement about the EB not getting the mileage of the 6.2 towing is probably way off the mark. From what I understand the EB is designed for economical operation throughout the range.
"While its 365 horsepower and 420 pound-feet of torque may look a bit down on paper when compared to the 6.2-liter V8, real-life scenarios prove that the EcoBoost has got the brawn where it counts most: right in the meat of the power band. Ninety percent of the boosted mill's torque is available from 1,700 rpm through 5,000 rpm, allowing it to match the bigger engine's 11,300-pound tow and 3,060-pound payload ratings."
If that isn't a postive enough and you still feel that going to the competition would be the better route here is a little bit of it compared to the competition-
"We took the opportunity to compare a 2011 EcoBoost-powered F-150 back-to-back-to-back with competitors from GM and Dodge. We'll be blunt: Chevy's 5.3-liter is completely outclassed in this company. Dodge's Hemi engine, however, felt as if it had plenty of guts to get the job done (390 hp, 407 lb-ft), but part-throttle conditions, such as when maintaining a steady speed up a slight grade or changing lanes to pass slower traffic, caused the Ram's five-speed automatic to drop down a gear (and sometimes even two) when the EcoBoost and its six-speed would resolutely remain in its current ratio and pick up the called-upon speed. That's the result of abundant torque. When we pressed further (not that it was necessarily needed), Ford's tranny would indeed downshift and summon plenty of reserve turbo-fed horses. Impressive power, and also a boon for fuel mileage. Toyota's 5.7-liter V8 (381 hp, 401 lb-ft) also fails to match the barrel-chested feeling of steady-stream torque experienced with the EcoBoost when towing."
Matthew I'm with you on your comments. Nice post!!
I think that the EB is going to turn out to be a powerhouse of an engine, but time will tell about it's reliability. I still think you're talking about a 200K+ mile engine here, but like many others have said, it does have a lot of moving parts and that makes me hesitant, but extremely excited at the same time.
But back to the OP's question about the tank size. I'm confident it's directly related to the economy ratings of the EB being higher than the mighty 6.2
As I posted earlier, I'm not against technology and new stuff, but I still have a bad taste in my mouth from Ford's "latest and greatest 6.0L diesel" as it was proclaimed back in 03. That engine was touted to be the greatest thing since sliced bread and everyone knows how that turned out. While it would run circles around the 7.3, too many of them had reliability issues too numerous to mention individually. I certainly hope that's not the case with the EB engines. But until they are on the road for 3 or 4 years with a sufficient track record, I'll stay with the tried and true NA engines. And for that there's no replacement for displacement.
on
They don't know as much about it as they like to think. Also it is amazing how many of those reliability issues I could pinpoint to owner not knowing what was going on with these newer diesels.
I can go on and on about it. Knowledge(or the lack thereof actually) was the killer of the 6.0, not the engine in of itself.
