Is it possible to "Zero out" the odometer?
Old Oct 8, 2010 | 04:34 AM
hav24wheel's Avatar
hav24wheel
Justa as the title says, is it possible?! I'm putting a new engine/trans in my 94 and thought it would be neat to start it out on 0 miles.
Old Oct 8, 2010 | 04:56 AM
EPNCSU2006's Avatar
EPNCSU2006
I don't think there is. It's probably still considered odometer fraud no matter your intentions.
Old Oct 8, 2010 | 06:15 AM
DBGrif91's Avatar
DBGrif91
^He's probably right. Just because you're putting a new motor and tranny in, the rest of the truck still has those miles on it.
Old Oct 8, 2010 | 07:02 AM
TexasGuy001's Avatar
TexasGuy001
After a certian year of age the odometer reading is exempt anyway. I bet there is a way to zero it. I was thinking about doing the same thing after my 5.8 swap.
Old Oct 8, 2010 | 07:17 AM
nflfreak43's Avatar
nflfreak43
drive it till it hits 400k.... at 400k it hits 0's again...
thats my being a smart *** answer...
otherwise, i really dont think there is a way for a regular joe schmo to do it..
Old Oct 8, 2010 | 07:30 AM
TexasGuy001
I thought maybe it could be done the same way you can reprogram the PSOM for different size tires.
Old Oct 8, 2010 | 07:53 AM
hav24wheel's Avatar
hav24wheel
Idk if its legal or not, but after I get this motor and trans installed, the whole drive train will be new in the last year, and all will be under 10,000 miles on them.
Old Oct 8, 2010 | 08:22 AM
wycowboy63's Avatar
wycowboy63
Resetting the odometer to all 0's is illegal, period. It doesn't matter what the intentions for doing it are.
Chris
Old Oct 8, 2010 | 08:38 AM
hav24wheel's Avatar
hav24wheel
Idk why it would be an a vehicle this old... When you sell a vehicle in this state, there is a box to check that states something like "odometer is not actual miles" so unless your changing it to fool someone, I don't see why It would matter...
Old Oct 8, 2010 | 08:54 AM
nstueve's Avatar
nstueve
Come to think of it... I want to do the same thing when i get my 5.8 swap done... I'll have a totally rebuilt drive train too... Only thing is... I have the older 5 digit odometer that rolls the numbers up... not the new electronic read out one... I am going to pull the dash on Thor and see if I can roll the Odometer back to "0"...
Old Oct 8, 2010 | 09:00 AM
hav24wheel's Avatar
hav24wheel
you might be able to do that.. I've done that on older styles like that before. just took it apart, and put the #s where I wanted them. I wasswapping speedos and wanted the odomometer to read actual...
Old Oct 8, 2010 | 10:03 AM
nstueve's Avatar
nstueve
sounds good to me! to answer your question... shouldn't you just be able to replace the PSOM with a brand new one??? that would put the milage back to "0" wouldn't it??? The PSOM is what stores the milage right???
Old Oct 8, 2010 | 10:11 AM
hav24wheel's Avatar
hav24wheel
Ya, I suppose so, but with this total rebuild on the 351W and swappin in the ZF, I'm spending enough $ wheree I was hoping I could find a free way.
Old Oct 8, 2010 | 10:22 AM
wycowboy63's Avatar
wycowboy63
I don't know why it would matter either but it does. Every state in the union has a law against it in addition to a Federal statute. Personally, I wouldn't buy any vehicle that the owner admitted to messing with the odometer. His intentions may or may not have been honorable but that won't matter to me. If he did that, what else may he have done that was also illegal that I might get popped for. Removed the cat? Also against Federal law by the way. But, its your truck, do what you want to do with it.
Chris
Old Oct 8, 2010 | 10:32 AM
Kapusta's Avatar
Kapusta
I know there are a few ways to add miles. I came across a few write ups on a Bronco forum. So technically you could probably run it forward till it hits 999999.9 and perhaps it would reset to 000000.0 after that.
One thing though. It wasn't proven that the odometer would reset back to zero after that or that it would just hang on all 9's in the display.
