54 f350 4X4 axles
Timkens, or maybe Eatons, that's it for 1954 conversions. Stock 2wd 3/4 ton or higher, would also be a Timken, unless half ton, then it's a Dana 44 in 1954. IIRC.
The front axle of the '77 might work, but the rear will be about 3-5 inches too wide. Figuring out the steering might be the tricky part.
And '77 should be open knuckle and front disc brakes.
I was supposed to hear from the fellow about my M-H/Timken frontend at the beginning of October, that hasn't happened. I plan to call; if he has lost interest, it will be available.
the A had the shorter pinion on it didn't it? but all the other mesurments seem to be the same ..so all the internals should work .. at least the parts I need..pulling the front hub's apart tomorrow .. the bleeder screws on the wheel cylinders are both frozen so new one's are going in .. I hope..
the A had the shorter pinion on it didn't it? (No, it has the longer pinion housing, the B150 is shorter. Picture of Owen's is below) but all the other mesurments seem to be the same (yes, since it's made to fit an F-250, which is essentially the same truck as the F-350, logically the whole unit should be a bolt in)..so all the internals should work .. at least the parts I need (that's not an assumption I'd be comfortable making)..pulling the front hub's apart tomorrow .. the bleeder screws on the wheel cylinders are both frozen so new one's are going in .. I hope..
on
do you know what is broken in the stock axle? if it is internal i would think it would be the shaft or joint. if thats the case have you tried dynatrac or currie bros.. they are both 4x4 axle shops that can make just about anything, think high pinion dana 60 rockcrawler or desert racing stuff. they might be worth a call before you go to put in a late model axle. and if it is internal cant you just remove the broken parts and get it on the road? maybe i am missing something but when i try to do one of those easy swaps i usually end up spending more than i would have to fix what i got. just a thought
it is internal the joint at the hub has blown the ear off the style I have is a large cup style with ball bearings between the ears..I was thinking of getting a late style c-v joiint and machineing the axle stub's to fit..I see the new style for 1400 bucks but they are for the open style new stuff..I know my old flatty is not gonna overstress the new stuff..and I would like to use my truck in the snow( if we ever get any)....right now it run's ..working on getting her to stop...then work on 4 wheeling...but I like to collect parts when they show up..
Eric Payne
09-25-1999 07:25 AM
