HVAC won't turn off with key?!?!?!?!?
Ok so I go to drop my daughter off at dance class, turn the key off and the blower motor is still running.
97 f250 7.3
My first thought was an ignition switch, so I stopped and picked one up.
Got home, unplugged the old switch and the blower is still running.
The fuse is staying hot all the time.
Kind of at a loss here, any ideas?
97 f250 7.3
Problem solved today,,,,,
Apparently at one time, a trailer with some shorted wiring was hooked to this truck, blew the brake light fuse,
No replacement fuses, ssooooooooo, a peice of wire jumpered from the brake light switch to #7 fuse to get brake lights, and the truck out of gear.
After the brake light fuse was replaced,, same jumper, backfeeds to #7, which in turn backfeeds to #1, and my hvac is on all the time!
Replaced some burnt wires, removed the jumper and all is well again!
lonnie
03-31-2005 09:53 AM
