Need approx. weight of 1956 F100
Curb weight of a 56 F-100 is 3460 pounds (max)
Your 460 with aluminum heads and aluminum intake will weigh within 75 pounds less than the 272 Y-block
The C6 with fluids and cooler will add 100 pounds.
9" no significant difference
Front subframe, add maybe 75 pounds.
So add 100 pounds to the 3460 for a curb weight of approximately 3560.
PS. If you are planning on renting a trailer to haul your 56 and you are planning on getting it from U-haul, be sure to tow it behind a full size truck and tell them you are picking up an 85 Honda Civic.
If you tell them you are picking up a 56 Ford F-100 or don't have a fullsize truck to tow, they won't rent it to you - insurance margins!
1956in1956
06-12-2020 09:39 AM
