FE Aluminum Heads - Torque Specs?
Hmm...using a torque spec should give you stretch per length though, not an overall stretch. I.e. if you were measuring them, the longer bolts will have simply stretched more when the wrench clickes @ 100 ft lbs ...
My guess is that it has to do with how much aluminum is between the bolt head and the block.
czaroc
18
04-11-2008 06:24 PM
bigred66
09-01-2007 08:01 AM
jamies460
06-19-2007 08:44 AM
S_Bruce
05-23-2007 11:57 AM
WrenchHead84
07-20-2002 07:26 PM
