Gear material for Sterling 10.25 axle in 1989 Ford
Hello all, I have a 1989 Ford F250 and the bearings and possibly gears in the rear axle went bad, would make an awful grinding noise whenever the throttle was released. Anyway I did swap in another axle but it is an older axle and doesn't have the port for the ABS sensor. I am a machinist intern and certified welder so I am good with working with metals and would like to rebuild the original axle from scratch. Would like to make my own gears and other parts. I have access to manual mills and lathes, CNC mills and lathes, EDM machines, etc. My questions are these, does anyone know what steels these gears are made out of? Does anyone know of any superior steels that could be used (would like to bulletproof it)? Does anyone know the hardness level on the stock Ford gears? Any help would be appreciated!
Thanks!
Thanks!
Oh absolutely, I just want to manufacture my own gears from scratch because it will be a good school project for me. Have always wanted to do something like that.
Not to rain on your parade, but this would be an extremely difficult, if not impossible project. The ring and pinion are hypoid gears which have an extremely complicated tooth profile, and you'll need to know the exact dimensions of the differential housing itself in order to properly create them. There is a ton of math that goes into hypoid gears.
You might be able to create the differential spider gears, which are standard bevel gears. But you'll need to use a good high-strength hard steel with a lot of impact resistance. It will likely need to be hardened afterwards and have a good heat-treat. Internet suggest 8620 or 9310 would be a material to use.
Yeah those machines are a blessing for sure! We shall see what happens. Thank you for your input!
I was going to post a similar statement as LeadHead. I don't see you doing this with some regular CNC mills and lathes. A custom crank is possible with those machines though..that'd be cool. My grandfather did that back in the day for a Porsche 4 cylinder, using manual lathe & mill. Took him hundreds of hours..its a work of art.
This is the internet, so maybe you can find the correct information on a machinists forum. There are some Youtube videos out there, not really how to videos but might give you an idea.
I don't. The machining in the YouTube videos i watched is like nothing I've been around. Google search for "hypoid gear cutting". Most of us on this forum understand what the gearset does, which set to run for given applications, some of the more skilled can set them up properly, but I doubt many know what it takes to actually manufacture them. I sure don't. So, I hate to steer you away from FTE, but I think you'll be better served elsewhere.
So, your pinion has come loose and is being pulled into the carrier on overrun? (axle driving engine)
Hobbing, grinding, heat treat and fixture lapping a ring and pinion are very specialized tasks requiring tools, jigs and ability beyond that of most machinists.
With all the advances in multi axis CNC recently, it would be interesting to see the tool path v/s workpiece programming needed to accomplish something like this.
You could probably write a master's thesis on this alone, and by the time you did, the state of the art will have changed to where it's not relevant anymore. (said by someone who remembers when g-code took over from paper tape)
joe f350
27
09-04-2010 09:36 PM
Bobby82490
10-06-2007 05:51 AM
scottek
11-14-2005 05:17 PM
scottie2hottie
07-30-2004 10:37 PM
