Under Valve Harness question??????
Old Sep 27, 2010 | 08:14 PM
Redeyeracing's Avatar
Redeyeracing
I have been throwing the p1316 with real rough running. I pulled the VC today and the plug was on straight but had about 3/16 of play when I pushed it together. Is that enough to throw the code and cause the code? All the wires looked good other than that. Any thoughts?
Thanks Nate
Old Sep 27, 2010 | 08:19 PM
F350-6's Avatar
F350-6
Yes that's enough to cause your problems. Did you shim the connector before you put it back together?
Old Sep 27, 2010 | 08:21 PM
Ponyboychris's Avatar
Ponyboychris
It should have no play whatsoever.
Old Sep 27, 2010 | 10:19 PM
Redeyeracing
I have not shimmed it yet. I still have the cover off. I am trying to decide if I should do the glow plugs. At the same time I started throwing the p1316 I started throwing 2 glow plug codes on the same side. Can the plug not being secure throw those also? Is the 50 cent mod the way to go or go with the Ford clips?
Old Sep 27, 2010 | 10:54 PM
SpringerPop's Avatar
SpringerPop
Yup. The glow plug current goes through the same connector that the injectors are fired through.
Costs you fifty cents to fix that.
Pop
Old Sep 28, 2010 | 08:09 AM
Brother Les's Avatar
Brother Les
While you have the covers off. Retorque the rocker arms, ect.
Old Sep 28, 2010 | 10:14 AM
jgilrfr's Avatar
jgilrfr
uvch
Yes,re torque the rocker arms,re torque the injector hold down plates,add a 6637,and a 5" exhaust,gauges,new turbo,HPX,fuelx over,international up pipes,BTS trans,do the hutch mod,zoodad,do it all do everything,quit your job and just fix or replace stuff on your truck,
Old Sep 28, 2010 | 10:22 AM
SGnAZ's Avatar
SGnAZ
And don't forget to delete everything
Old Sep 28, 2010 | 02:28 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I used the Ford clips because I had them already. The quarter method looks like it works well and many people have used it with great results. With my luck, I'd grind it down too much and it'll fall out or not enough and I'll break something. I would also be a (little) nervous about having a piece of metal right on top of what International calls a 'high voltage' connection.
That being said, if I didn't have the plastic clips then I'd probably just use 2 quarters like most of the members here.
As an added benefit....at least your truck will always be worth at least 50 cents, no matter what the condition.
