Center seat instead of center console
No, with the centre seat you don't get the rear air conditioning vents and you don't get the 110V outlet. There are heating vents under the driver and passenger seats though.
I use the storage space under the front seat to run a dual-port 12v outlet to the back seat (attached to driver's seat down low, for the back passengers), and run a 150W inverter to supply 120V when needed. I just lift the seat and plug in whatever one I need, or both.
Crew cab or super cab can have the console.
The XL has a console option but it is a much smaller console.
If you have the console, you have the two rear air vents and the 110v plug.
If you have the front middle seat, you don't have either.
I have a super cab with the console so it has the two rear air vents and a rear 12v and 110v. I'm not too impressed with the air flow volume from the two rear console vents but it's not bad. I haven't even used heat yet so IDK if there is rear heat in the SC.
I can slide "stuff" under my seats so there aren't heat vents in the floor.
Sure, no problem, just give me a few days -- the truck has gone back to the dealer to repair a scrape on the front fender from when they delivered it. I should have it back in a couple of days.
Did you not get to look at the truck before buying? Just asking.
You may already know this, but just in case... Did you know there is additional, lockable storage below the center seat up front? I agree, the console storage itselft doesn't offer much, but between the two up front, it works just fine for me. Mine was locked on delivery, so you need to make sure you unlock it if it doesn't come right up when you pull the handle.
Had the same seatup in a 1967 chevy -factory buckets with jumps seat with box underneath - mine held 8 tracks -
I guess I just aged myself...
