Aerostar Ford Aerostar
AOD downshift problem
Old Feb 21, 2003 | 01:56 PM
quicktruck's Avatar
quicktruck
I have a 1988 Aerostar AOD that kicks down with a very light application of throttle. Everything else works great, smooth shifts, no slipping. good downshifts when I stop. I have a hard time speeding up or going up a hill on the interstate with out it shifting to a lower gear. My van will actually slow down when it does this because the rpm is not enough to maintain the speed with the lower gear. How do I adjust how much throttle causes a kickdown?
Thanks,
Mike
Old Feb 21, 2003 | 02:58 PM
aerocolorado's Avatar
aerocolorado
Unless someone is pulling your leg, your transmission is an A4LD, like all the other Aerostars. Sounds most likely that your kickdown cable is out of adjustment. For a quick confirmation, look at your throttle pedal. At the top of the pedal you should see a wire cable that extends through the pedal and continues outward toward the driver's seat approximately 1 to 1.5 inches (this is just a rough estimate). If your cable end stop is closer than this to the pedal when the transmission is in PARK, then the cable requires adjustment. A decent manual will explain all the particulars.
Hope this helps.
LARIAT 85
'80-'86 HOWTO's
33
Apr 24, 2026 09:07 AM
LARIAT 85
17
Dec 26, 2020 09:51 PM
LARIAT 85
Sep 7, 2016 01:22 PM
jfrizman
Oct 16, 2013 04:20 PM
jpeckham
Mar 11, 2013 02:12 AM
