Need help guys on a 01 ranger.
Old 09-26-2010, 02:32 PM
FIREBALL 00's Avatar
FIREBALL 00
FIREBALL 00 is offline
ok usually i just look over the forum and browse but recently now i need your help guy's. I tried to get my grandfathers 2001 ranger 4.0L rolling again but its a no go. Ok here's the deal he got sick and hasnt drove it for awhile. The truck run fine slick as a dime but recently i tried to start it up & it almost started to crank all the way up to run but then the battery died on me. So i go and get him a new battery regardless cause the other was old and it needed replacing. Then after putting the new one in it turns over fine but wont start up? Does anybody know what could be causing it not to start when before it would start up just fine the truck run very good. It has maybe 45,000 miles on it and trust me its not been ragged out and then it does this?? Someone help me out please its too nice of a truck to just be sitting around on a newer set of tires.
Old 09-26-2010, 02:45 PM
g_k50's Avatar
g_k50
g_k50 is offline
will it start with gas sprayed in the air cleaner?
Old 09-27-2010, 01:41 AM
FIREBALL 00
i gotta go by there tuesday again and im going to try some more things on it ill try that as well....and report back ....
Old 09-27-2010, 04:19 AM
V8Ranger302's Avatar
V8Ranger302
V8Ranger302 is offline
My guess is the fuel pump locked up. Try banging on the gas tank with a rubber hammer at the same time try turning it over. Make sure bang on the under side of the tank, in the middle. If it starts you know its the pump.
Old 09-27-2010, 11:28 AM
FIREBALL 00
Originally Posted by V8Ranger302
My guess is the fuel pump locked up. Try banging on the gas tank with a rubber hammer at the same time try turning it over. Make sure band on the under side of the tank, in the middle. If it starts you know its the pump.
gezzz lol are you serious? the fuel pumps that bad on these trucks or what ......ok well i'll try that thanks ...
Old 09-27-2010, 02:33 PM
V8Ranger302
Ya, fuel pumps arnt what they use to be, lol. Especially if its been sitting for a while.
Old 10-04-2010, 07:56 PM
jimw411's Avatar
jimw411
jimw411 is offline
Try replacing the fuel filter and while it's off, blow compressed air towards the inlet line back into the tank to blow off any debris on the pick up sock in the fuel tank. When fuel sits a while it turns to crap and can plug things up.
Old 10-07-2010, 07:39 PM
chromeclassicxl's Avatar
chromeclassicxl
chromeclassicxl is offline
How long has it been sitting? Is the gas in your area mixed with ethanol?
Old 10-07-2010, 10:31 PM
FIREBALL 00
I havent had a chacne ot work on it but yea its been sitting for alittle while and i know the ethonol crap makes gas turn faster to garbage basically hey anybody know if theres a fuel reset button on this 01 4.0L ranger?
Old 10-08-2010, 03:35 AM
V8Ranger302
Reset button?? Did it get hit in the ***? Thats the only reason you should have to reset one of those. Like I said before, Bang on the middle of the bottom of the tank with a rubber hammer or something while trying to start it. It should free it up so it will start....
Old 10-08-2010, 09:24 AM
StillaKilla187's Avatar
StillaKilla187
StillaKilla187 is offline
Could just be bad gas. Same symptoms on my 1994. I drained the tank, all the lines, and replaced the filter. After a couple of cranks it started rough, then eventually burned out all the crud and ran fine. The drained gas was a rust color. So maybe drain a couple gallons and see what the fuel looks like.
Old 10-08-2010, 09:52 AM
FIREBALL 00
yeah so i got a little time to go over and mess with the truck and found when i turn on the key & best as i can tell im not hearing the pump priming on startup so......yeah im going to go back over there and take a 1/2 day this next week to mess with it including banging on the tank, draining the fuel (as much as i can), fuel filter, and so on i would've tried more today but i noticed the battery was getting weak so i stopped ill get on it next week like i said and have a charger chargin on start mode, ....i got a good question for you if and when i do have to drain some off the tank whats everyones best method of doing so? Reason i ask is the truck is in a carport and all i got is stock ground clearance to mess with it and thats it.
Old 10-08-2010, 09:58 AM
03 Maz B23's Avatar
03 Maz B23
03 Maz B23 is offline
Fuel pump reset is located behind passenger kick panel. They have been known to trip. If you give fuel tank a rap be carefull as tank is made of plastic. Depending on how much gas is in tank you might want to add a gas can or two of fresh fuel to aid in getting it going. If you try starting fluid give it a shot at end of air intake by throttle body not by mass air flow sensor at end near air filter or you could damage it. You could also try cleaning mass air flow sensor with electrical cleaner to rule it out as a cause.
Old 10-08-2010, 10:05 AM
FIREBALL 00
ok yeah i was thinking of cleaning the maf cause im sure its never been cleaned regardless, thanks for the info no the switch im going to figure it out hopefully when i mess with it next week. thanks .....
Old 10-08-2010, 10:21 AM
StillaKilla187
I just used a siphon pump i got from walmart for like 5 bucks and drained all the fuel into 5 gallon buckets. Total of like 13gallons of bad fuel. Then i put 5 gallons of good fuel in.
Quick Reply: Need help guys on a 01 ranger.
