Installing an Auto Meter transmission Temp gauge.
#31
Some more related helpful information from a recent discussion here on OBD devices...
https://www.ford-trucks.com/forums/1...l#post16035670
Rich (Tugly is his username) has a TON of helpful posts and information both in his signature line as well as his posts. Run a search for his screen name and have fun sorting through everything that pops up - way more information than you'll know what to do with, and if you can't make an informed decision off of all that info then I dunno what to tell you...
#32
It can be hard narrowing down which cheap obd2 device to get. Some batches of the same device are truly elm 327 compliant and some aren't. Some can only read a couple of active pids at a time before slowing down and some are fast with many pids.I read a lot of recent reviews when I bought my last one and ended up with a short blue one from Amazon that cost 10 bucks. It works great. It even worked with forscan to program a pats key, something they say the cheap readers won't do. For the price though, it was worth the risk of buying a few until I got a good one. There are better ones available that are made to leave plugged in 24/7 shutoff so they won't drain your battery as well. All depends on your planned usage.
#33
The phone App does not allow me to search and i paged through the posts quite a few times and could not track this
I have an Android phone that is mounted to the windshield and I want to have it on and monitor when running. would like to have it run all the time.
PJ-Hunter
20
04-16-2020 01:24 PM
Truck Noob
02-21-2016 09:45 PM
