Emergency Flasher Trick
Old Oct 12, 2010 | 09:54 PM
jsimon724's Avatar
jsimon724
Yeah
You can take a standard 20amp fuse and slip it right in the 3 & 4 slots while your trailer's hooked up. Lights up your stop and running lights. Not really functional, but looks cool at night around the campsite. Just remember that it'll cause your lights to burn out sooner (better carry some spare 1157's), unless you're running LED's.
Old Oct 13, 2010 | 10:23 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Thanks, guys! Added to the Tech Tip sticky!
Old Oct 15, 2010 | 11:57 PM
sandyc's Avatar
sandyc
OK, I'm a real dummy here. You say all you have to do is plug a prong flasher in slot #3 and #4 and the tail lights will start flashing? Does this flasher somehow get power from the battery when vehicle not connected? Great idea if that's all their is to it.
Old Oct 16, 2010 | 12:18 AM
arctic y block's Avatar
arctic y block
Trailer has to have it's own battery
Old Oct 16, 2010 | 12:19 AM
dchamberlain's Avatar
dchamberlain
The tail lights and marker lights, actually.
Pin 4 is the wire that normally sends power from the truck to the trailer to charge the trailer batteries, if your trailer has batteries that are charged by the truck. When the connector is disconnected, there will be power on pin 4, since it's basically just hooked into the trailer batteries.
Pin 3 is the marker and tail lights.
Put a flasher relay between the two and you've created your own emergency flasher circuit.
I haven't tried this, I don't have anything to try it on. But it seems like it should work.
Old Oct 16, 2010 | 12:23 AM
sandyc's Avatar
sandyc
My RV does have a battery, so the flasher thing should work OK. Thanks
Old Jul 29, 2012 | 06:37 PM
phantomphixer's Avatar
phantomphixer
Also works as a locator when amongst numerous travel trailers and when parking in the north woods and somebody needs to locate you after dark, as in your hunting buddy that is always late and cell phone service is out.
FYI the best place to camp has no cell service. Then you're at the beginning of life
Old Jul 29, 2012 | 07:20 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Exactly! Places I long for.
Got my flasher in the tool box!!! (third drawer down)
Old Jul 29, 2012 | 10:52 PM
Frankenbiker's Avatar
Frankenbiker
Just as a quick note here, there are two types of 2-prong flashers; the cheaper one is a thermal flasher, and the more expensive one is electro-mechanical.
The thermal unit can sometimes be problematic if you're trying to flash more than 2-3 lights at a time; it will flash much faster (or sometimes slower) if you're trying to flash a lot of lights. It's designed to be used in a car that doesn't tow trailers. The variation in flash speed is what's supposed to clue the driver in that a turn signal bulb is burned out.
The electro-mechanical version will handle many more lights, and give you a much more consistent flash speed.
-blaine
Old Sep 17, 2016 | 07:23 PM
Just Strokin's Avatar
Just Strokin
Thought would pop this trick back to the top so others might learn this trick with an old style flasher.
Old Sep 17, 2016 | 07:58 PM
Chuck's First Ford's Avatar
Chuck's First Ford
I have had for 3 years.. a plug in switch into the 7 pin on the trailer. for all outside lights to be on.. so Wife can locate trailer after dark..
and now will add a 2 pin flasher...
if you like use a 3 pin wig/wag turn signal flasher from a late 70's Chevy. and have turn signal lights flash alternately
Old Sep 17, 2016 | 08:13 PM
Tomc750's Avatar
Tomc750
Did this trick to brother in laws trailer when group camping. The electrical engineer in him could not figure out what was going on. This was a good 20 yrs ago. We still laugh about it!
Jody Johnston
Jan 4, 2018 07:54 PM
6LitersOfFun
Jun 21, 2017 06:11 PM
brobrad
Dec 11, 2016 07:57 AM
martinbarrio
1978 - 1996 Big Bronco
May 15, 2016 02:26 PM
meporsche
Apr 3, 2016 04:05 PM
