starting and fuel pump issue
First of all I am new to this forum and new to ford trucks.
Picked up a 1986 f150 xlt two weeks ago. This truck has two problems, so far.
First is the starting problem. The truck wasn't cranking at all, so I replaced the following: starter, battery cables, starter cable, starter solenoid. The alternator looks new, previous owner said it was replaced a couple months ago. Had the battery charged and checked ; it's good. Now when I go to crank the truck it completely drains my battery. Im not talking about attempting to start it for about 10-15 minutes, it only takes one or two tries to drain the battery. Swapped my battery from my camaro and it did the samething.
What can be causing my battery to drain after one crank?
Second problem is that the fuel pump next to the drivers frame rail stays running when the key is on.
thanks in advance
thanks in advance
What does the engine actually do when you try to start it? Does it turn the engine over at all? Nothing is going to be able to "drain a battery with one crank". There would be a lot of smoke if that happened.
Also try this: Turn the headlights on, and while someone is watching them, try to crank it. Do the lights stay bright, or do they go completely out when you turn the key? Do you hear any clicking noises?
I agree with Franklin2, I can't see how a battery can be virtually instantaneously discharged
using a mere starter motor in a few seconds without everything self destructing, there would
be lots of smoke & heat & melted wiring & sulfuric acid everywhere. This can't happen.
Have you performed the test mentioned with the headlights? What about the clicks?
What is telling you the batteries are suddenly dead? Have you verified this with a voltmeter?
As for that wire, I'd leave it disconnected until I found out exactly what it's supposed to be
connected to. All of Ford's ground wires are black, I suspect the loose end in that picture
has got another loose end somewhere as a mate.
I just re-read your first post and see that you have all new battery cables, so it's probably not a bad connection. Are you sure they are hooked up correctly?
The starter mounting surface was dirty because it looks like it has a leak at the oil pan.
Anyone have a wiring diagram for the engine bay?
Sounds like you have a open circuit or drain. Check the fuse box and make sure there hasnt been any P.O.'s bad wiring. IE: they ran a cable from like a kill switch/radio amp/radar/etc and the other side of the wire in the fuse panel is "bridging" the fuse and it stays open(aka constant power)
Test by hooking everything up (ignition off) and seeing if you can find a 12v draw on the dead side of the fuse. (pull the fuse out to test)
Also check your neutral safety switch, a bad one can also cause a overnight drain. (d.s. tranny)
