Where can I buy WRIST PIN bushings and CAM bearings?? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 09-24-2010, 01:16 PM
mongo75's Avatar
mongo75
mongo75 is offline
mongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to all
Since the damn machine shop says they're are too busy to mic my wrist pin bushings today (I probably won't be going back to these guys btw) I want to be proactive in the case that they are a bit out of tolerances. I also of course wanna slap new cam bearing in it too. I haven't tried NAPA, but then again I don't want no stinkin' made n China crap in my block either!
Thanks!
Old 09-24-2010, 01:33 PM
mongo75's Avatar
mongo75
mongo75 is offline
Nevermind- answered my own question. Got both cam and wrist pin bushings from San Marcos Ca International. $185 plus shipping. Damn these parts are EXPENSIVE! Next time it blows I'm dropping a Chevy 350 in for under a grand!
Old 09-24-2010, 03:46 PM
Martika 7.3's Avatar
Martika 7.3
Martika 7.3 is offline
Martika 7.3 is gaining momentum as a positive member of FTE.
Wink
QUE! Hell No! No Mutts Aloud! Chevy Porfavor, Buena Mierda! Seriously, U Should Have A Reliable Motor For Years To Come! You Are Building Her Up Right! Good Luck With The Machine Shop!
Old 09-24-2010, 03:50 PM
Martika 7.3
BTW! Nothing Is Cheap On Our Trucks!
Old 09-24-2010, 04:28 PM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
man I missed this..I could have hooked you up..i have learnd the molly pistons and rings are what the 700-800 hp guy's are running so I went with molly piston's 20 over ..they come with the molly rings and wrist pins but I also got all my bearings from the same place that makes and coats bearings for all the nascar motors... I'm not doing my own build..there are no machine shop's near me that can do the work I want and need.like line bore a diesel block or cut the heads for fire rings or even balance the crank....for less then the cost of shipping to have it done...I can have this guy build it for me and warranty it .I have a sled puller in PA doing my build (not your average back yard i want a pulling truck guy..but a really strong make a living pull truck)...he has all the contacts for these good parts...everything going into my motor is in his motor running 700-800 HP...course he has a griddle,bigger cam,sticks turbo and as of a couple months ago running crower rod's..till then he was running cryoed stock rods and i mine are being done now..so I should have a very nice built motor for 600 HP with out a problem for the tune of $ 6k give or take....
z31freakify
11-17-2016 09:15 AM
85bobtail
03-30-2012 08:48 AM
88f1504x4
10-16-2011 10:23 AM
adamtheman16
08-06-2010 07:14 PM
toolboxjunky
05-19-2010 08:32 PM
Quick Reply: Where can I buy WRIST PIN bushings and CAM bearings??
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
