1998 E150 4.2 Throwing P-0174, 0301, 0171, 1131
Hi, and welcome to FTE!
It seem most times your situation is a result of vacuum leaks or clogged EGR ports.
Being a '98 either could be the case (due to age and mileage).
You can use "search" up top to search this forum for older posts and threads.
Here are a few that might help.
https://www.ford-trucks.com/forums/9...rror-code.html
https://www.ford-trucks.com/forums/8...-too-lean.html
Ford P0171 & P0174 Lean Codes
Check the vac hoses at the rear of the upper intake manifold near the firewall, they have little rubber booties that crack and split, giving you a lean condition. I wish I had found this before I went off on a wild goose chase on my 98 4.2. These actuate the IMRC valves and they are only a couple bucks. I recommend replacing them both, it should solve your problem. Funny thing, about a year later I got the same codes again and this time it turned out to be a similar cracked vacuum hose booty in the front of the upper intake.
