Heres one for ya
Old Feb 21, 2003 | 12:40 AM
knocturnal's Avatar
knocturnal
Heres one for ya
ok boys... heres the issue. when you go to hit the gas on my truck if you just barely touch it it will buck and almost die and then hit high idle < this is efi > and its starting to **** me off when im trying to do something like haul wood and important things like that... any help appreciated. thanks
Old Feb 21, 2003 | 07:09 AM
couleeman's Avatar
couleeman
Heres one for ya
My Jeep did that, it was a combination of the automatic choke and fast idle sylinoid. The Jeep is carb though. Don't know if this is much help to you.
Old Feb 21, 2003 | 07:45 AM
steve83's Avatar
steve83
Heres one for ya
Pull the codes and get a Haynes manual or look here for the procedure to test the TPS & IAC with a multimeter. Also, check the whole ignition system.
Old Feb 21, 2003 | 01:04 PM
Ando5O's Avatar
Ando5O
Heres one for ya
My truck used to do this too. I would hardly touch the gas and it would die. The problem ended up being the automatic choke.
Old Feb 23, 2003 | 01:13 AM
steve83's Avatar
steve83
Heres one for ya
Huh? Your '93 doesn't have a choke.
Old Feb 24, 2003 | 07:13 PM
GammaDriver's Avatar
GammaDriver
Heres one for ya
I had this problem... in fact many of us have.
My suggestion?
Read EVERY post you can find (use the search engine) in the archives and in current threads about restricting (and/or blocking) the EGR on EFI Inline Sixes.
There are so many posts about it that you probably won't need to post any questions about it. Plus it is cheap, it has worked for just about every poster who tried it (that responded back) (save for one that I can remember), and it is easy to do.
Best,
Butl85
2009 - 2014 F150
Apr 18, 2012 07:10 PM
rednekrebel28
20
Dec 29, 2010 07:45 PM
BPofMD
Illinois Chapter
Apr 19, 2008 09:02 AM
baker_racing05
2004 - 2008 F150
Nov 28, 2007 11:46 AM
RXFreddie
1983 - 2012 Ranger & B-Series
Apr 28, 2007 08:40 PM
