Rough Idle?
Rough Idle?
Quick question for the board. I took the 99 Expy 5.4L (76k miles) in the kwick Car for a normal Oil Change. This time I had them flush and change the Transmission fluid and install a new fuel filter. However, ever since this was done, the truck has had a rough idle and it gets even rougher with light acceleration. Moderate to Heavy acceleration are smoother, but not quite normal. I say not normal, because it seems that the power is down slightly (maybe my imagination). This morning I took the truck back to the station. I had them replace the fuel filter again, in case I got a faulty one. But the problem remained. It is just too much of a coincidence that the truck started running poorly right after a fuel filter change. I put in a can of Berrymans B12 into the gas and have run about half through. Still no change. Running consitantly rough, but never seems to die, even at cold start. What should I do next? The mechanic suggested that I change the plugs, since this has never been done.
Your advice would be greatly appreciated. BTW, the truck has never had a history of any problems. (other than the "normal" right head gasket leak ; )
Thanks for your help
R/
Sbauld
R/
Sbauld
Rough Idle?
Considering what they did to your truck mechanically, they shouldn't have "messed" anything up. I'd start by disconnecting the battery for 10-15 minutes. This will reset the computer. Then go out and drive as it as you normally do. The truck will act a little funny for a few minutes while the computer reprograms itself, but it should run smoother. If this doesn't help, try pulling some codes rather than guessing.
