Exhaust suggestions for 01 250 5.4l crew shortbed?
Hello all,
I'm looking for suggestions for an exhaust system to replace the just rusted-out stock.
So far all I could find for dual is Cherry Bomb but it's not stainless. Flowmaster has stainless, but only single. Magnaflow doesn't list an exact fit (actually for the v10).
Thoughts?
Thoughts?
Just make sure you replace your Y-pipe. The stock y-pipe is a source of restriction.
00-04 Ford F250 F350 Performance Y Pipe 6.8L 5.4L V10 V8 | eBay
Here is thread of the system I installed on my dads truck. I have the same system (with a few tweaks) on my truck also.
https://www.ford-trucks.com/forums/8...tback-2-a.html
The single 3" is plenty for the 5.4l and thats what I use on 6.8ls also. The above kit is a little louder than stock but not annoying at all. Both systems have been on for several years here in SE PA and are still in good shape. The 5.4l and 6.8l catbacks for the same year and model are identical as far I can tell. I agree with also replacing the necked down portion of the stock y-pipe with the SPD unit. 5 Star tuning also sells the Y-pipes.
https://www.ford-trucks.com/forums/884789-flowmaster-catback-2-a.html
Looks great and has the SS I want (flowmaster has an exact fit SS in stock).
What is the y-pipe issue and who sells those? I assume this is in front of the cat?
I'm in SE PA as well - Downingtown area.
You can see what the necked down y-pipe looks like in the pic.(Top pic)
http://makinhay.net/exhaust/ypipes.JPG
The SPD y-pipe replaces just the necked down portion and welds in place. Its not a must have item but you can pick up a little power with it, especially with a custom tune.
Y Pipe 2000 - 2004 for 5.4L / 6.8L/ RV /Super Duty's - 5 Star Tuning
http://www.spdperformance.com/index....ikcjmcru88i6s1
The Flowmaster kits use nice mandrel bends. Both kits I installed are aluminized because Flowmaster only recently came out with a stainless kit. The clamps that came with my kits were not good so I didn't use them. I fabbed up the hanger/clamp on the rear of the muffler out of 304 stainless so it will never rust out. I've had my system on probably over 4 years now and so far so good.
i installed a Borla single exit 3" stainless kit and it sounds great. Its louder than a stock exhaust but no annoying droan when towing or anything. Stainless looks brand new after this winter's salting. FYI Flowmaster are junk, their mufflers dont flow any better than stock one did, id go with another company, also Cherry Bomb is a great upcoming company, their products are top notch and from the flow test ive seen they flow like crazy!
Narwhal
06-14-2005 01:20 PM
98fordf250ld5.4l
Exhaust Systems
08-11-2004 04:30 PM
