Removing wheel well cover
If you're talking about the front fender liners, I have some pics of the process in my headers writeup here:
2004 F250 Broken Exhuast Manifold Stud
Basically, you have to make sure you get ALL of the screws, bolts, and push clips out. There's a few under there that are kind of hidden under all the years of road grime. Once they're all out you can push the whole thing inboard and upward and start working it out around the wheel opening.
If you're talking about the rear... sorry, I don't know for sure
Thank you
Not much info on this topic. Thanks for the pics! Along with the wirite up. I'm installing a new air horn on the Ex.
I just had to pull mine to replace the IDM. I removed the obvious smaller screws at the lips edge. I also found the larger screws up under where it goes flat behind the front bumper and on the side between the shock and floor board. I also removed the three plastic securing tabs under the floor board area at its edge. It was hard to get it to come out away from the edge...it didn't need to come completely out. I went to put it back together and couldn't get the edge back over the lip. Come to find out I had missed one of the larger bolts up in the top of the wheel well, and once that was loose it became much easier. I was going to swap the IDM from the Excursion to the F350 for a test, but then I realized how much more trouble that liner is to do given the fender flare trim.
Hey, I just ran across this one and the pic in the link are broken, but
https://web.archive.org/ to the rescue and there was a PDF which I attempted to attach, but failed. The link to it is here: https://web.archive.org/web/20170829...250ExhMani.pdf
