Early 60's FE question
Old Feb 19, 2003 | 11:29 AM
pward76's Avatar
pward76
From the 67-72 forum...
quote:
Originally posted by Rat wagon
for cheap you could just build a motor like a 390 to early
sixtys specifications and bam you got 335 horse and 426 ftlbs torque from a stock,and alot cheaper rebuild kit, plus it's bullet
proof, no mucking around with mixing and matching cams lifters
and so on. You get bone stock reliability with enough juice to
bark the tires at 50mph with sand bags in the back. I like
the early setup.... alot
but it sounds like you want major horsies though!! I can't help ya
there sorry.
Interesting point. I'm wondering how I go about building a 68 390 to early 60's specs. Is it as simple as getting early 60's heads? How early in the 60's - is there a cutoff year? Can I modify my C8AE-H heads to the early 60's specs - I know I can go to CJ exhaust valves, and grind down the thermactor humps in the exhaust ports. Would this compare to an early 60's head specs?
Old Feb 19, 2003 | 12:48 PM
Rat wagon's Avatar
Rat wagon
There is no real advantage to building to early sixties spec's, I should have said 60's spec's of the 390 car engine. A 68 390 4v in a fairlane etc. was cranking out 315 horse, or more?
This extra comes from 9.6 to 1 compression, a 4v, and maybe a slightly different cam or cam timing. I didn't build the engine
in my truck, It barks the tires only when I down shift to pass at 50mph. I am pretty happy with it, it pulls better with 3.54's than my 390 2v did with 4.10's.
It could be a 410, which would explain the power, I'll check that so I ain't misleading no one as You can tell I have very limited knowledge, but I get by somehow
Old Feb 19, 2003 | 01:52 PM
pward76's Avatar
pward76
Still, the question remains. If I want to build an early 60's CAR engine, would I simply bolt on the correct heads, intake and carb, and be good to go, or would I also need pistons, rods, etc. to achieve the 9.6:1 compression as compared to my 8.6:1 in my 68 2V 390?
Just curious. I really like the idea of upping my horsepower to the 355 range from the 255 (IIRC) rating that my current truck carries, and doing it inexpensively.
Old Feb 19, 2003 | 05:13 PM
Ratsmoker's Avatar
Ratsmoker
The C8AE-H heads are probably every bit as good as the early heads. The early 390s made their power through slightly better intakes, higher compression and bigger cams. 335HP is cakework for any rebuild with most any stock parts if you get the compression up and use a good cam. Today's cams are much improved over the old designs. Using a stock cam is a waste for a performance build in my opinion unless you just have to have the exact factory feel. A guy that used to post here lightened his truck to about 3,400 lbs used unported completely stock C8AE-H heads, 9.5:1 pistons, a 230 degree elgin cam, an RPM intake and flowtech headers and was running 8.65 in the 1/8th. You can make decent power with these heads. He had 4.56 gears. My truck has made a best 1/8th mile time of 9.2 seconds on street tires with 3.70 gears. Digging around for early 60's parts is not worth the effort.
Old Feb 19, 2003 | 09:25 PM
pward76's Avatar
pward76
Thanks Ratsmoker, I remember econodrag. I was sorry to see him go.
Old Feb 19, 2003 | 09:34 PM
Ratsmoker's Avatar
Ratsmoker
Yeah, he is probably running around on the cougar forums somewhere now. His 390 bit the dust in an odd way. The cylinder wall gave out on the non thrust side. Wasn't even being raced when it happened. I went and saw the remains. It wasn't pretty.
Blue50F-1
13
May 10, 2013 12:41 PM
speedracer1000
Sep 8, 2009 11:23 AM
BLUEMERC
Nov 24, 2005 09:24 AM
squbjob
Nov 5, 2003 06:33 AM
flpanhead
Mar 11, 2001 10:50 PM
