Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
- How to Replace Spark Plugs
Step by step instructions for do-it-yourself repairs
Spark Plug thread repair. With Photos
#31
Blew another plug on my way camping on the 4th of July this weekend. However, I had everything handy to make a quick repair and continue camping. I found humor in my mishap as a bicycle rider was right next to the truck when the plug blew. He probably thought I was throwing firecrakers at him.
#32
Blew another plug on my way camping on the 4th of July this weekend. However, I had everything handy to make a quick repair and continue camping. I found it humor in my mishap as a bicycle rider was right next to the truck when the plug blew. He probably thought I was throwing firecrakers at him.
#33
I believe most of these blow outs are caused by the plug backing out and then wearing out the threads.
I have taken to torquing mine every 30 thousand miles or so. So far no more blow outs.
Sorry you blew another but glad you were prepared. I wouldn't have been. I did not take my timesert kit this weekends trip to the east Texas lakes.
#34
art and few others in here most likily remember i worked vw for 45 years before retireing, 2 companies making plug thread repair kits that work are these. and work i do mean,i do ford motors left and right at home and use both kits. useing this one for alloy heads as the kit keeps the proper heat transfer back to the head.
Spark Plug Thread Repair Inserts
the time sert ++ TIME-SERT Threaded inserts for stripped threads, threaded inserts, thread repair stripped sparkplug's, Ford sparkplug blowouts, threaded inserts threaded, repair stripped threads, stripped threads, inserts threaded inserts, Ford spark plug repair, has been around for at least 40 years and also works great, never use a helicoil for a spark plug,only use a solid insert .
#35
2000 Excursion V10 blown plug
When the #3 plug blew out on my 2000 Excursion V10, the local dealership repaired the plug opening with helicoil. That was two years ago. Recently, when I replaced all the spark plugs, the #3 plug would begin to loosen as I turned it counter-clockwise. Then it would tighten up while I continued to turn the plug counter-clockwise. I returned to the dealer and was told they could not help unless I wanted to have them replace the head. Otherwise I have to live with the plug as it is. I was able to tighten it up.
Any thoughts on removing this plug? Or should I live with it until it fails to work?
#36
I think you need to spend some time @timesert.com and learn about how to repair Triton spark plug threads without removing the head . Here is the link;
++ BIG-SERT Oversized Spark plug thread repair kits ++ spark plug thread repair for oversized holes previously repaired spark plug holes threads stripped
Everything you need to know is here .
Good luck,
Good luck,
#37
blowing plugs from alloy heads is age old problem with new tech from time sert and locknstich which I prefer that makes repairs a dream.
#38
Well it is 2014 and my V10 is still going strong. The Timesert is still holding and I did my second spark plug replacement some time ago. Time Timesert was still perfect and did not show any sign of getting loose.
I have 220,000 miles on the clock and the only repairs have been a fuel pump and I replaced the AC clutch because it was worn out. Still working but worn completely out.
Burn or leak about 1 quart of oil every 3000 miles. Yes the front seal leaks a little. That started about a year ago. It is not bad enough for me to mess with fixing it.
I wounder what 300,000 miles will look at. I have at least one more trip over the Rockies planned before that. The truck has made the trip about 10 times so far.
Next truck. Echo Boost? Likely not a Diesel since the EPA ruined Diesel. Or retire in my Motor Home and switch to a Jeep TOAD?
#39
Hello FTE Guys!
I need to change my #1, 4, 9 Coils (Based on The code reader) and being a newbie for the 2003 F-350 Triton V-10, I have no clue which cylinder is which.
Can anyone send me a link to a diagram or a picture. Thank you!
Pointing me in any direction is better than staring at the wall, THANKS!
ROB
GetaHandleOnit
ROB
GetaHandleOnit
#40
Hello FTE Guys!
ROB
GetaHandleOnit
ROB
GetaHandleOnit
Might want to think about a full on plug job while your at it. Search around for some tutorials on it. The modulars have what I would call a complicated process for spark plug changing. Not hard. Just time consuming and picky about order of operations.
Check out a few tutorials.
#41
Passenger side is 1-5 with one being closest to the radiator. Driver side is 6-10 with 6 being closest to the radiator.
Without offense youse toose are jumping onto a thread that completely is NOT about your issues. Spark plug (threaded hole) repair and COP and/or spark plug replacement are vastly different issues.
Typically you'll find the fastest and best advice by posting a separate thread.
BTW changing plugs on Modular Motors is not that complicated but does require careful attention to a few details. Those are readily available here too.
#43
Step-By-Step Pictorials
THANK YOU GUYS
for the Step-by-step Pictorials with detailed instructions!
YOU ROCK!
After reading many threads to find a similar problem to mine, I actually stumbled upon other tutorials that were extremely helpful!
So Hats-off to those who take the time to "Lay-it-all-out" for us newbies.
And thank you to those Moderators who reply to us that don't know how to find the appropriate thread to post into, AND don't Hammer us about it!
THANKS
From the Newbie
ROB
GetaHandleOnit
YOU ROCK!
THANKS
From the Newbie
ROB
GetaHandleOnit
#44
#45
