32 spline to 36 spline steering gear conversion opinions
i have an 02 f350 with a build date of 05/02. i have not confirmed by checking the tag or counting the splines but it appears that i have a 32 spline gear box. after 05/02 they were built with 36 spline shafts. is there any strength gains worth the conversion to the 36 spline box? i think that the only other part to change would be the pitman arm. has any one done this? thank you for any thoughts or opinions on this.
sorry, i have a drw. is there a trick to editing the signature? the gentlemen from redhead said all 2002 f350's came with 36 spline, but in my search for a core, i found that they also came with 32 spline. i think but can't confirm that everything built on or before 05/02 was 32 spline.
In my experience the only ones that have the 32 spline are the early 99's, could be others but not to my knowledge. I swapped mine from a 32 spline to the later 36 spline since mine was starting to wander pretty bad. No difference between the boxes, physically or steering except in my case better because of the worn out box.
Did anyone ever fully answer your questions? I have a 99.5 f350 2wd SRW and it has a 32 spline. In another post you can actually check the pitman arm serial number to verify whether it is a 32 or a 36. I'm wondering if i should just order the 36 spline redhead and get a 36 spline pitman arm. But not sure if there's more to it than that. Did you ever find out?
I know the four-wheel drive trucks switched to 36 blinds in March of 99. I believe all four wheel drive trucks have 36. As for two wheel drive trucks, I am not 100% sure. My 2000 f250 two-wheel drive has a 32 spline. It seems that they jumped around with 32 and 36 on the two wheel drive trucks. And of course putting on how old the truck is you never know what somebody else has done so my truck might not have the factory steering gear.
idiabuse
04-09-2017 10:53 PM
Sous
12-14-2015 03:12 PM
tl1965
11-26-2015 07:15 PM
