SRW door sticker survey
Old 09-10-2010, 09:48 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
For those of you who have 4x4 Single Rear Wheel trucks, would you mind posting the information from your door sticker please? Here is an example of the information I am looking for:
Build Date: 05/99
GVWR: 8800 lbs
Front GAWR: 4800 lbs with LT265/75R16E tires @ 55 psi
Rear GAWR: 4670 lbs with LT265/75R16E tires @ 50 psi
Axle Code: C1
WB (Wheel Base): 156"
Then, if you have the factory springs still, I need to know if your truck has 5 leaf springs on the rear. (Don't worry about the size, thickness, deflection etc), just count the springs.
Lastly, do you have a helper (Auxiliary) spring? (Yes/No).
I am looking to confirm a relationship between tire PSI as listed on the door jamb to GAWR for each axle. I have checked 8 different SRW trucks at work and was surprised at the differences in GAWR (especially the rear) on otherwise identical looking trucks.
Thanks for your help.
Old 09-10-2010, 10:30 PM
clem1226's Avatar
clem1226
clem1226 is offline
clem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to behold
Build Date: 08/99
GVWR: 9900 lbs
Front GAWR: 5200 lbs with LT265/75R16E tires @ 55 psi
Rear GAWR: 6830 lbs with LT265/75R16E tires @ 80 psi
Axle Code: doesn't say?
WB (Wheel Base): 172"
5 leaves on the rear, 4 full length and 1 short on the bottom of the stack.
Old 09-10-2010, 11:01 PM
Stangrcr1's Avatar
Stangrcr1
Stangrcr1 is offline
Stangrcr1 has a good reputation on FTE.Stangrcr1 has a good reputation on FTE.
06/00 built
8800 GVWR
5200 front at 55psi same tires^
6084 rear at 70psi same tires^
No axle code
WB 158
6 leaves plus upper overload and plus straight lower overload for a total of 8.
Old 09-10-2010, 11:04 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
5 spring pack plus overload. Give me a call, whenever, about fuel pressure after FPR rebuild.
Old 09-11-2010, 01:23 PM
kelwar
kelwar is offline
kelwar is starting off with a positive reputation.
Build date: 03/02
GVWR: 8800 LBS
Front GAWR: 5200 LBS - LT235/85 65 PSI
Rear GAWR: 6084 LBS - LT235/85 80 PSI
Axel Code: C1
WB: 158
Springs 4 full length 1 short one on the bottom and 1 overload = 6 total
Old 09-11-2010, 02:01 PM
ghig1967's Avatar
ghig1967
ghig1967 is offline
ghig1967 is gaining momentum as a positive member of FTE.ghig1967 is gaining momentum as a positive member of FTE.
Build Date 5/01
GVWR 8800 lbs
Front GAWR 5200 lbs LT265/75r16E @ 55 psi
Rear GAWR 6084 lbs LT265/75R16E @ 70 psi
Axle Code C1
156" WB
5 rear springs with helper
Old 09-11-2010, 02:19 PM
clem1226's Avatar
clem1226
clem1226 is offline
weird
too short
Old 09-11-2010, 02:28 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Too old to be too smart
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Build Date: 05/00
GVWR: 9900 lbs
W/B: 172"
5 leaves in the stack, and a "helper" above.
Pop
Old 09-11-2010, 02:29 PM
Waynenap's Avatar
Waynenap
Waynenap is offline
Waynenap has a good reputation on FTE.Waynenap has a good reputation on FTE.
Build Date: 07/02
GVWR : 8800 LB.
Front GAWR: 5200 LB. LT265/75R16E @55PSI
Rear GAWR: 6084 LB. Lt265/75R16E @70PSI
Axle code: C1
WB: 156
5 springs with an elevated helper. 6 total.
Old 09-11-2010, 03:00 PM
Shake-N-Bake
Interesting.
Thanks guys.
So, the whole purpose of this was to research and possibly confirm an incredible statement I heard over the weekend from some rock crawling co-workers. I was working in our San Francisco branch this past week and the guys were talking about their weekend plans. One of them was on the hunt for a Super Duty Single Rear Wheel axle. Apparently the Sterling 10.5" axles have developed a reputation for being quite strong and durable and a lot of guys like to use them in their rock crawling machines. These machines are mostly home built off road vehicle with massive tires and expensive suspension components. Apparently the Sterling axles can accept axle ratios at high as 7.17 and have a GAWR of 9750 lbs. So, they think these axles are super strong and are only limited by the weight the springs and tires can handle.
Anyway, the claim is, it doesn't matter if the truck is an F250 or F350, nor does it matter what the door sticker says about the axle rating. It only matters if it's a Super Duty Ford '99-'05 because these guys believe all the trucks shipped with the same exact axle. The difference in GAWR on the door sticker is determined by the psi of the tires and not necessarily the spring pack that was installed. The spring pack is determined by the options list checked off when the truck is ordered (heavy duty, camper, plow package etc).
I was a bit surprised by this idea because I always thought the springs made the difference in rating. However, now that I've seen quite a few door stickers....I am inclined to believe that the GAWR is determined by the Tire Pressure listed on the label, or at least this was how Ford came up with the various axle load ratings. Ford must have some good reasons for the variety of ratings because it would be simple to list 80 psi on all the trucks and call it good. But they didn't and as a result, we have all these variety load ratings on the stickers.
Looking at the results of this post and the stickers from my shop trucks..it appears on the rear axle:
50 psi=4670 lbs.
55 psi=4970 lbs.
60 psi=???
70 psi=6084 lbs
80 psi=6830 lbs
(I didn't list 'kelwar's' rating because his tires are different...2WD?)
Does anyone have a sticker that lists 60 psi with the LT265/75R16E tires? That seems to be the missing link. GAWR should be about 5500 lbs-ish?
So, if this idea has any merit....then is it reasonable to assume that we should air up to 80 psi when we have heavy loads in the bed? I've been using 80 psi myself for years.
Thoughts and comments are appreciated.
Thanks.
Old 09-11-2010, 03:57 PM
SpringerPop
I believe that the rock-crawling guys are correct in their thinking that the SuperDuty Sterling housings are all the same strength, but you are very correct, too.
The differences in weight ratings are to maintain certified-safe handling characteristics for legal liability reasons. This takes into consideration which spring pack is installed, as well as the tire construction ratings, inflation pressure, and class rating of the trucks.
Pop
Old 09-11-2010, 04:11 PM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
I have a 10.5 LS 3.73 out of a 99 F250 sitting in my shop. Its been on CL for months and no responses.
I guess they do last, if no one needs one.
Old 09-11-2010, 06:16 PM
kelwar
kelwar is offline
My truck is also a 4x4 I think the reason for the different tires is because mine is an xl although I have seen xl that come with 265s
Old 09-11-2010, 11:33 PM
Shake-N-Bake
Thanks for the follow up. I wonder why your truck came with different tires. Interesting for sure. Did you notice that everyone's axle code was C1 or not listed? Weird.
Old 09-12-2010, 02:51 PM
RFD_Truckie's Avatar
RFD_Truckie
RFD_Truckie is offline
RFD_Truckie is starting off with a positive reputation.
Build Date: 10-01
GVWR: 8800 lbs
Front GAWR: 4400 lbs with LT235/85R16E tires @ 60 psi
Rear GAWR: 6084 lbs with LT235/85R16E tires @ 80 psi
Axle Code: 31
WB (Wheel Base): 142"
There is a helper (Overload) spring... forgot to count the leaves, Will update that info...
Truck is an extended cab XL series work truck
Quick Reply: SRW door sticker survey
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
