tracking an oil leak
Old 09-09-2010, 11:25 PM
150ford
150ford is offline
150ford is gaining momentum as a positive member of FTE.150ford is gaining momentum as a positive member of FTE.
I am having an oil leak on the back off my motor just behind the oil filter in the steel valley. Just curious if anybody else has had an oil leak that is common to these engines. I am going to try an tackle it here in the next few days. Any input would be appreciated. Thanks for any help.
Old 09-09-2010, 11:52 PM
150ford
150ford is offline
This a 2003 7.3 PSD truck. Any input would be appreciated.
Old 09-10-2010, 12:12 AM
binuya's Avatar
binuya
binuya is offline
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
Do you mean behind the fuel filter? If so, leaks in the valley area are very common. HPOP and turbo pedestal leaks usually. Clean it up, start engine, and get in there with a flashlight, inspection mirrors, and paper towels.
Old 09-10-2010, 12:15 AM
150ford
150ford is offline
Just curious if these are easy fixes? Have you had these issues with your truck? Just want to know what i am getting in to. Thanks for the input.
Old 09-10-2010, 12:35 AM
binuya's Avatar
binuya
binuya is offline
I had a plug on my HPOP blow an o-ring. It spewed quarts of oil within a few miles. I wound up getting the correct o-ring from a
Ford dealership parts counter. That particular one requires Loctite, which came with the o-ring. Other potential leaks are the HPOP lines or the turbo pedestal. They're all relatively easy to fix, and if you do some searches on this forum, you'll find they are quite common.
Old 09-10-2010, 05:24 AM
JonathanN's Avatar
JonathanN
JonathanN is offline
JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.
Yeah, it's simple... just be meticulous and clean about how you take it apart and put it together. I had my HPOP output line O-rings go and MAN did it make a mess... I had oil all over the bottom of my truck! But the guy above is right... sop up all the oil and then watch which end of the valley pan the oil starts filling from (there are horizontal lobes in the pan that look like ribs that will collect oil). If it starts filling from the front, it's HPOP-related. If it starts filling from the rear, it's turbo pedestal-related. I haven't done the turbo so if that's your problem, then you're gonna have to get some input from others on here.
Old 09-11-2010, 11:18 PM
mgrove1983
mgrove1983 is offline
mgrove1983 is starting off with a positive reputation.
When the hpop leaks it drips into the valley then down the back of the motor and makes it appear to be a rear main or something of that nature. There are many good threads telling how to fix these issues but i doo suggest that while your in there to replace all the o rings and the non servicable plug. you can ussually pickup everything you need in a kit.
Old 09-12-2010, 04:58 PM
150ford
150ford is offline
Thanks guys
Ok one more thing anybody on here sell the O rings to fix this.Or a kit for this. Im guessing its the HPOP pump the way the leak looks. Ill tear in to this in a couple off days.
Old 09-12-2010, 06:05 PM
binuya's Avatar
binuya
binuya is offline
Here's the best place I've heard of around here:Replacement O-rings for Ford Diesel Engines
Old 09-13-2010, 09:32 AM
JonathanN's Avatar
JonathanN
I was gonna post that, but you beat me to it... he's the guy top get 'em from!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
