oil leak - dammit man! Louisiana/TX shops??
I've got about 10k miles on new engine and I had an annoying oil leak at the dipstick for awhile, but I finally just RTV'd the hell out of it and stopped it from leaking THERE.
Now I am 100% certain the front main seal or oil pump or whatever is behind the crank pulley has a very minor leak - its kinda sweaty with oil after 1000mi drive. This may be from when my Gatorback belt was shredded by water temp sender wire (popped out of holder and rubbed belt until it failed). I just found peices of belt 'strings' wrapped around front of crank - maybe when belt failed and these strings wrapped around crank they compromised seal??
The disturbing thing for me now is the drip from ZF6 bottom 'vents'. I had seen minor puddling there, but thought it was just being blown back and dripping down front of trans, but after a VERY thorough cleaning - it kinda looks like maybe its coming out of bellhousing?? I pulled inspection cover off and it was wet with oil on inside, but no indication of oil on backside of the flywheel...
I'd like to find a shop nearby to do the front seal and evaluate if there is STILL a leak. I'm working near Sulphur, LA but may go visit friends in Houston next week (wed-sat). Can someone recommend a reputable shop or extremely generous enthusiast who can help me????? I have enough tools on-board to do about anything - but I am absolutely MISERABLE in this damn HEAT and HUMIDITY!!! I'd be happy to pay someone to work on my junk! (there is a first time for everything - I guess...)
Thanks!
Thanks!
And if you don't find any volunteers, call David Lott in Houston and see if he can get you in. Diesel Innovations - Contact Us
Thanks y'all. I'd be happy to buy Rick and/or Roland dinner for an opinion!
Yeah, I'm sure the leak is down low - the top of the motor is squeaky clean. Since EVERYTHING was squeaky clean, its pretty easy to clean fresh oil off and see where it comes back... Right now, the front of the oil pan gets wet after 100mi - but the only other place I see oil is a drip from bottom of trans. I'm hoping some oil from dipstick and front seal leak got in bottom of bellhousing and is still working its way out.
I do love the bayou! Well, not the heat, humidity, skeeters and lovebugs (right now...) - but I do like the FOOD! Gumbo, jambalaya, all the cajun cookin'.
Was the rear seal changed on the new engine? Hopefully it's not that and we only have to change an o-ring or two.
When I get a minute later, I'm gonna go thru my pics and see what rear seal looked like. From the little reading I've done, it looks like rear seal can easily be installed wrong?? I cannot say it hasn't leaked since day 1.
on
I just talked with Rick and we can probably coordinate a GTG for next weekend, to do the repairs. Maybe you and he can get together, beforehand, and determine the cause of the leaks.
I retired from Halliburton in '06. I worked offshore for 25 years, so you know I know Fourchon and Venice very well. lol.
