rust kill
Old Sep 9, 2010 | 09:00 PM
anderson sc's Avatar
anderson sc
rust kill
Gave it a good cleaning then soaked inside and outside with 2 gals of OSPHO (phosphoric acid) rust kill, using a pump sprayer. I have used this for years don't hear much about others using it? Used this rust kill method for years on all my restore projects with good luck. It really gets down in between the tight spots. Just wondering your all's input? Still have to paint but not as quick as sand blasting. I got the truck rust killed, primed inside and out and the front removed in just a few days. At $125 for primer $30.00 for rust kill. Working on the brakes, replacing lines, hoses etc. Going to leave everything stock.
Old Sep 9, 2010 | 09:04 PM
anderson sc
Old Sep 9, 2010 | 09:06 PM
anderson sc
Mervy49's Avatar
Mervy49
Is that "rust kill" a brand name? Were can it be purchaced?.....thanks in advance for your response
mervy49
Old Sep 9, 2010 | 09:08 PM
anderson sc
Old Sep 9, 2010 | 09:16 PM
anderson sc
OSPHO get it a any paint / hardware stores. HD has it, Kean-strip brand.
Old Sep 9, 2010 | 09:25 PM
old58's Avatar
old58
I have used the same sort of thing with great results, but your right, you don't hear much about that method. We had a shrimp boat, the metal rigging operated in the most caustic environment of all, salt water. At the local marine supply we were able to buy "Rust Kill", basically the same thing as ospho for a lot cheaper than the name brand stuff. We'd clean the rust off as best we could, paint that stuff on, then topcoat with paint. Anyway, works great, last a long time, probably a lot longer since your not covering the parts in salt water and spray. I used the same thing on the steel wheels on my F-5 and painted them white, so far, nothing is showing through. J
Old Sep 9, 2010 | 09:50 PM
anderson sc
long time ago 20+yrs someone told me he'd would use meratic acid to etch the paint service before he would paint anything. This stuff also does the same thing 1 part to 3 parts water! Don't seemed to be as strong acid type base but you should read lable for safety.
Old Sep 9, 2010 | 10:17 PM
BlueOvalRage's Avatar
BlueOvalRage
DBIBFFDQ
I just used some Ospho tonight on some valve covers for another project. It's good stuff!
Old Sep 10, 2010 | 07:02 PM
raytasch's Avatar
raytasch
Believe Nothing
Good stuff. I am using it on a 1955 Ford 850 tractor at this time. Been using it on cars and trucks for years.
ray
MikefromMT
Appearance & Dress-Up
Feb 13, 2026 09:37 AM
gstirewalt
Apr 18, 2016 01:53 AM
Strokt350d
6.2L V8
Jul 2, 2014 06:53 AM
zamunda
1997 - 2003 F150
Mar 1, 2010 09:12 PM
tbm3fan
19
May 24, 2008 12:04 PM
