Undercarriage knocking when starting.
Does it knock just once? A second or two?
How much does your engine move on startup? You may need new engine mounts.
What style of hi-beam switch is it? If it's the floor mounted style, they can succumb to corrosion and fail. If it's on the columb, I would start by checking relays and fuses.
It could be the exhaust ill check that.
