97 F150 trailer plug wiring diagram FAST!!!
i need to tow a trailer tomorrow which has a 7 pin plug on it. i dragged a$$ on my plug shortly after i got the truck and messed up the plug. so i went to walmart, bought a new 7 pin plug for $20 and i just need to wire in all the old wires into the new one.
i need to know what colors are for what function. IE...white=ground etc. please help, i need it fast.
truck--------------- controller---------------- what it does
New Ford (Pink Wire) -------------- Pink Black --------- +12 Volts
Red --------------- Red ---------- Stoplight
White -------------- White ------------ Ground
Blue --------------- Blue ---------- Trailer Brakes
Brown --------------- N/A
Ford - older
Red --------------- Black ---------- +12 Volts
Lt Green -------------- Red ----------- Stoplight
White ---------------- White --------- Ground
Dark Blue ---------------- Blue --------- Trailer Brakes
Brown ----------------- N/A
Ford - older
ok, if you promise to be a good boy.
Off a Ford service disc as C456 info page.
1 = YEL = L turn.
2 = WHT = gnd.
3 = Dk Blu = elect. brakes.
4.= Dk Gn = Right turn.
5 = Orange = battery.
6 = Brn / Wht = running lamps.
7 = Blk / Lt Gn = reverse lamps.
The terminal count begins at 11 o'clock from the socket key and goes counter clockwise to term 6 at 1 o'clock looking at the front of the socket
Term 7 is inside the center..
It is remotely possible the color code might be different.
Use of a voltmeter will ID all the functions.
For example; put the 4 ways on and see terms 1 and 4 flash power and left/right single turn signals.
Good luck.
1 = YEL = L turn.
2 = WHT = gnd.
Good luck.
Try this Diagram also, same as above, but it has pics!
http://www.f150online.com/forums/ele...nd-wiring.html
RV_Tech
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
11-06-2016 03:53 PM
wasmblad
07-22-2013 10:05 PM
pzp107
05-17-2013 08:12 PM
