Eagle crank and rods vs. stock crank, rods
Is the cost of a new Eagle cast crank $239+ tax and shipping plus Eagle Forged I beam rods $365+ tax and shipping worth buying over using Ford factory crank and rods, how strong is the stock stuff. I would like to put that money toward something else toward my engine but will buy the Eagle set up if i need
Factory crank and rods are good for around 500hp with no problems, The forged H beams that I had in the 429 build are actually buried in a box somewhere, the 460 in the video is stock 460 crank and rods, around a 1976'ish model.
Figure if you are looking around $400-450ish for the stock rods (shot peen $15 per, ARP bolts $65, resize $20 per, magnaflux $3-5 per, press fit pistons $8-10 per) the $365 for Eagles are the better price, even with S/H, its a better rod, and on top of that its a floating design instead of press fit.
The shop you are using may have better prices and if thats the case you may want to stick with the factory rods, if not, then go with the stock crank and use the eagle rods.
dying breed racing
05-19-2015 03:47 PM
shazam
25
11-19-2002 02:33 PM
