Radius Arm Bushings.
I started getting a vibration from my truck on the highway at around 50MPH that got me worried. When I looked underneath I noticed that a leak from the steering box and about 35 years of aging has caused the radius arm bushings to disintegrate on the drivers side. Now I have to change them out and want to know, what is the best way to get that done? How much do I have to take apart to get those things changed out?
If you're going to start replacing bushings at the radius arm, you might be best served doing the rest along with them. You can buy the kit at JBG with C bushings, rad bushing and track arm bushings pretty cheap. You'll need to break most of the stuff loose to replace the rad bushes anyhow. Hang your front axle and start unbolting everything. 12 bolts all together.
I posted this same question and got some good responses. If you do a search you can read what others say about this. I to have a 2wd and need to do mine. Most say just to pull forward on the axle and the arms come out. Do one side at a time. then pull them back into place with a come along. Didnt sound tough at all but I wanted to make sure.
LITTLE BLACK TRUCK
27
08-13-2015 02:30 PM
topfisherman
1978 - 1996 Big Bronco
06-10-2004 10:48 PM
loudfords
07-25-2002 05:42 AM
maison302
03-17-2001 11:10 AM
