F250 in the Mountains
I just bought this to tow a fifth wheel with. We haven't purchased the 5th wheel yet, looking for a 28 to 31 footer. We are thinking of a Forest River Wildcat 28RKBS. The truck is a 2010 Lariat with the 6.4 PSD, also has the camper package. I welcome any advice on fifth wheels!
One other thing I would like to add. A 5er tows so much better on the highway than a trailer and esp. if the winds come up. However, when it comes to backing up it is a totally diff. animal. A trailer responds almost instantly and a 5er seems to take forever but when it does look out. I have to admit I'm not a big rig driver but I could back trailers up a lot easier.
Let me add my 2 cents here. Get your truck on the cat scale. About 9 bucks is it.
Save the ticket so you can refer to it later.
Now look at your driver door pillar. See the cert label. Should give you your axle ratings for each axle.
Now compare to what it says on the ticket, subtract and that is what you have to play with.
Most of the 5er wt will reside on the rear but some will go forward as well....a couple of hundred pounds.
Hope that helps.
Hope that helps.
Thanks for the replies, I work for a heavy construction company (we build highways) so getting a weight is not a problem. There is an RV show coming up soon just north of us, we are planning a trip to get some more ideas. I appreciate the advice on what to look for and hope to be posting about our travel adventures soon.
I have two small 2000 watt generators that can be run individually or in series.
These are gas ones. I have a 6 gal external fuel tank that is good for 3 days running both if needed.
They come in at 45 lbs each.
They have built in inverters/surge protections so that you can run computers and such.
Also will shut down if low on oil.
WWW.KIPOR.COM
WWW.KIPOR.COM
I carried a small gas generator (1850W) in my tool box to power my air compressor in case of emergency. Never used it while traveling and never tied it into my 5er. It was my security blanket.
johnarahill
12-28-2011 05:58 AM
tinman52
17
08-29-2011 09:18 PM
