HELP! Cannot get oil filter cap off? What is the trick?
This is the socket I use: Lisle 14500 - Filter socket oil fuel for 6.0 liter Ford diesel
http://www.tooldiscounter.com/ItemDi...le&kw=LIS14500
I wouldn't order from them shipping is more than price of tool. Just want to give you an idea what it look like
I believe Auto Zone Carries them also
It's my preference to use a 6 point 36mm socket. This one is specifically designed for Ford diesel oil and fuel filters. It is 3/8" drive.
Amazon.com: Lisle 14500 Oil Filter Socket: Automotive
However, before I got this socket, I just used a large adjustable wrench on the nut. Make sure the wrench is tight on the nut and goes over the flats all the way.
I've heard that using a 1/2" drive can break the cap as well. So I've always used the 24mm socket.
Edit: I guess if you want the whole set...
http://www.toolsource.com/24mm-drive...-p-107891.html
Lisle , 13310 24mm 3/8" Drive Low Profile Filter Socket
HFCM (frame) fuel filter cap is: 25Nm (18ft/lb)
Fuel filtercap top of motor is: 14NM (8ft/lb)
