Split Shot Injectors?
Old Sep 2, 2010 | 04:29 PM
MauleOne's Avatar
MauleOne
I just bought this E99 F350 with 160K. It runs great but I want to use it towing a 5th wheel long distances and need it to be reliable.
I figure it has never had injectors "O" rings replaced or the injectors rebuilt (?).
Which are better? The split shot injectors or the single shot?
I know one of the FTE members sells "o" rings sets so I will go there.
Old Sep 2, 2010 | 04:49 PM
superduty4x4's Avatar
superduty4x4
Single shots will require a custom burned chip because your truck has split shots stock. Singles are noisier but make more power because there isn't fuel being spent on the pilot shot like there is with splits. Nearly all performance injectors are single shot.
Old Sep 2, 2010 | 05:07 PM
Izzy351's Avatar
Izzy351
They're also more efficient. More power, better economy, but a little (and I mean *a little*) noisier. I don't even notice the difference anymore. Worth it if you're changing stix anyway, for sure.
Old Sep 2, 2010 | 05:16 PM
cangim's Avatar
cangim
is it pretty much required to re-tune between split and single shots? I have an E99 as well that I about ready to change sticks out on and have been wondering this. I figured singles would be slightly louder, but really, running a 38r isn't quite anyway.
Old Sep 2, 2010 | 05:25 PM
superduty4x4
The computer won't like having singles with split programming, or vice versa. It will run, but poorly.
Old Sep 2, 2010 | 05:53 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
If you aren't having any issues with your stock injectors I would run them. If you are worried, buy or borrow an AE and see how everything looks. If you are set on buying injectors I would go with Alliant 'AC' or Reman Stage 1, same thing just Alliant are new. Only thing is with an Early 99, IMO, more fuel may push your stock turbo a little hard and create higher EGT's while towing. Just something to keep in mind.
Old Sep 3, 2010 | 10:21 AM
MauleOne's Avatar
MauleOne
Injectors
Clay
Thanks for the response. I am not having any problems with injectors now. Only considering the thought because of the idea of having them out to change the "O" rings for preventative maintenance.
Be interesting to see which injectors I actually have. This truck is a very early 99 with a build date of 03/98 on the door.
Could do the .50 mod while I am in there.
Old Sep 3, 2010 | 10:36 AM
superduty4x4
You'll have AB's unless someone has changed them in the past.
Old Sep 3, 2010 | 11:04 AM
MauleOne's Avatar
MauleOne
Injectors
Thanks for the info
Old Sep 3, 2010 | 11:11 AM
Riffraff Diesel
PREMIUM SPONSOR
If you aren't having issues I wouldn't consider injector o-rings preventative really. Unless you just really want a project I do admire your commitment to thinking ahead of having issues though.
Old Sep 3, 2010 | 03:02 PM
MauleOne's Avatar
MauleOne
Injectors
Thanks
I got the training course from TurboTraining.com and it talked about the "o" rings being a failure point due to the high pressure pulsating oil causing erosion.
Nothing I want to tackle soon.
