5.0 engine = big oil pump after rebuild
All, I need some help desperately... I rebuilt my 86 5.0 (Mustang engine) - EFI - and below are the mods I made. The problem is, when I start the thing up, it bilges oil to the intake and the exhaust BIGTIME.
- bored .040 over
- crank turned .010 under
- block decked .010
- 1.6:1 roller rockers
- MAC timing gear set (2° cam advance)
- removed A/C
- removed AIR pump
The first time this happened, I thought it was the rings, so I took the mill apart, replaced and triple-checked the new rings, and re-installed. IT DID IT AGAIN!!! I am thinking that it might be the heads, as those were never touched and have 150k hard miles on them, but I can't see anything. Has anyone else ever come across this? If not, can anyone tell me what could be wrong? My machinist is clueless, and so am I... Please help, any addvice would be MUCH appreciated! Thanks guys!
Mike
- bored .040 over
- block decked .010
- removed A/C
- removed AIR pump
Mike
OK, all cylinders SHOULD be firing. The injectors all spray nice, the plugs all fire on their own wires, the compression is great. There is WAY too much oil going through for it to just be valve guides. I heard that the head gaskets for that engine can go on only one way. I'm almost positive I put them on right, but if I didn't, is that a possibilty? Thanks again guys...
Well, I got it fixed. I tried to spray Ether, but it started bilging oil from the first crank, so the ether didn't have a chance. What I did was disconnect the coil wire, drop 2 qts. of Slick 50 in the pan, and crank it over for about 30 seconds. Then, I drained the oil, re-connected the coil wire, and fired it up. After about 10 seconds, I heard ALL of the cylinders fire up, so I let it run for another 30 seconds or so, then started adding oil back into the pan. It took about 2 minutes to get all 5 qts in, and by that time, it continued to run flawlessly, and no longer pumped oil. I ran the engine for about 45 minutes to make sure the oil rings were properly expanded and it wouldn't happen agian. I let it sit for about 2 hours to cool down, then re-fired the engine. Runs like a champ now!
ColoradoFordBoys
08-28-2014 06:10 PM
Ranchero460
08-16-2006 01:05 PM
sampsin
11-08-2003 03:52 AM
