ate up front tires on a 600 mile trip whats up ???
Check it out, my suspension is eating up my MTR's, Whats the deal???? I fixed my sway bar and installed a new steering column now after a 600 mile run towing the 5th steering is staring too eat away at my tires. I noticed the wheel has began to lose center and it's still a little loose up front, but much tighter than before with the worn steering column bearings and broken sway bar bracket. a 600 mile run should'nt have ate away that much tread on the inside of that tire. It also loosk like the endlinks (I think) are showing clean threads like they have backed themselves loose. I don't know what do you guys think?
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
<o></o>
<o></o>
<o></o>
Yep, its alignment time, BUT, Realize that youre about to change the wear pattern again, and you may see a little more quick wear, but then once the wear pattern is established you will be good to go.
Always get an alignment when you get new tires. have the alignment tech print out what the alignment rack shows your angles to be before and after the work. Most shops will check your alignment for free, but if it is out of spec they expect you to pay them to bring it back in spec. The great thing about a Super Duty is that once you get it in spec, it usually stays there. In 10 years of owning my truck it has only been aligned three times. It has been checked 20+ times, but they have only had to turn a wrench on it 3 times.
Something else I have learned is that you will see faster front tire wear if your truck does not sit level when loaded with your 5er. If you drive nose high there is less weight on the front axle, and the pavement acts like sand paper on your tires.
Looks to me like the clamp was left loose and over time it ate at the threads and pulled them clean off. That and on the inside of the tire it looks like it may be rubbing on something at full lock; that's a lot of stress if it is binding up. I don't know if these things have steering stops on the knuckle but they need adjusted if they do.
So I pulled the adjusting coupling and the threads are'nt stripped. They bolts were not exactly tight, not loose either just 20 lbs of torque roughly. The front tire were off and balanced two weeks ago, no signs of rubbing then. everything seemed to begin to go south about the last 100 miles. Tommorow I'll get her up on jack stands and see what I can figure out.
At this point I would replace the collar anyway and check the threads on the rod very carefully for any problems. Replace as necessary.
