Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
2001 Lightning- No power under boost?
Old 04-14-2010, 03:20 PM
Cali84's Avatar
Cali84
Cali84 is offline
Unhappy 2001 Lightning- No power under boost?
Hello,
I have a 2001 Ford Lightning with 80K miles on it. All stock motor with exception of exhaust. On the way to work today I accelerated on a freeway on ramp to get infront of a semi and when the supercharger went into boost from vacuum I experienced a great loss of power and a shudder. Motor runs fine as long the supercharger is in vacuum, but once you start to lay into the throttle and the supercharger kicks in I lose power and it almost feels as if I have hit rev limiter as far as the shudder and loss of power, but thre RPMs are nowhere near redline. Any ideas?
Thanks!
Old 04-14-2010, 10:08 PM
lil_dq's Avatar
lil_dq
lil_dq is offline
cats clogged?
Old 04-14-2010, 10:23 PM
patrickke's Avatar
patrickke
patrickke is offline
it maybe bad injectors and your not getting enough fuel, or even a clogged fuel filter... check the small stuff before the big...it could even be an air filter...also see if any codes are being thrown
Old 04-15-2010, 10:46 AM
Cali84's Avatar
Cali84
Cali84 is offline
Yeah, my friend has a code reader that I am going to check out tonight. I have been doing some research and it sounds like it may be something wrong with the Supercharger Boost Solenoid. It runs like a charm under normal load in vacuum, I know these have secondary fuel pumps, I guess there could be an issue there with fuel delivery. Thanks for the reply and ideas!
Old 04-15-2010, 10:48 AM
Cali84's Avatar
Cali84
Cali84 is offline
Originally Posted by lil_dq
cats clogged?
I thought of that, but generally you would have the rotten egg smell, right?
Old 06-19-2010, 09:27 PM
Lightning Rod's Avatar
Lightning Rod
Lightning Rod is offline
Unplug the boost actuator on the right side of the blower case and see if that solves your problem. If it does, just leave it unplugged.
If that doesn't do it, check to see if your MAF is still plugged in.
Old 07-21-2010, 03:40 AM
basswave83's Avatar
basswave83
basswave83 is offline
Im having the same problem. Just had the heads replaced and the mechanic can not find any vacuum leaks. There was a code that came up, when the check engine light came on, for excessive fuel and he fixed that but no change in the way it performs. Also, it sounds like there is air blowing through the vents but there isn't. As of right now, there is no engine codes coming up. Did you find out what was causing your problems?
Old 10-01-2010, 11:24 AM
King Leo's Avatar
King Leo
King Leo is offline
MAKE SURE YOU HAVE THE CORRECT PCV VALVE AND THAT IT IS WORKING !!!
Bkennedy1
1999 to 2016 Super Duty
28
03-23-2017 08:16 PM
lhardy830
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
12-28-2015 06:22 PM
jsdonaldson
1997 - 2003 F150
09-26-2011 05:18 AM
powerplant_f100
31
12-29-2010 07:42 AM
fordextreme
01-15-2002 07:22 AM
Quick Reply: 2001 Lightning- No power under boost?
