Mis Fire in Cylinder 2 and 8 Or thats what it says anyway
Old 08-31-2010, 11:22 PM
GoodwinFord's Avatar
GoodwinFord
GoodwinFord is offline
Well just put a new exhaust on my truck and every time im at WOT it would stutter or run rough not horrible but a noticible amount. So my check engine light started flashing the other day as my truck was running like crap even when i barley pushed on gas. So i turned it off turned back on and now its fine except for when i put the pedal to the floor. So the check engine light is still on but not flashing anymore and i pulled the codes and it says misfire in cylinder 2 and 8.
My questions are
-Can the exhaust be causing this
-Could it be Coils or spark plugs(Truck has 85,000 miles)
-Is this the cam phaser that almost everyone seems to have trouble with.
-Or any ideas of something else that may be causing this
Thanks for all your input
Old 09-01-2010, 07:13 AM
EBTDM's Avatar
EBTDM
EBTDM is offline
Time for a tune-up anyway so start there, and while your at it look for exhaust leaks.
Old 09-01-2010, 10:44 PM
GoodwinFord
well could an new exhaust set up cause a mis fire? I didnt touch any of the cats just muffler
Old 09-01-2010, 10:50 PM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
If there's a serious blockage it could. A significant amount of back pressure will cause misfiring.
Seems to be alot of misfiring on the board here the last couple of days...
What kind of muffler was it? You can also move around the #2 and #8 COP and injector to other cylinders and see if the misfire code follows them. If so you know it's not the muffler.
Oh, you can also try reseting the PCM...low probablility it will fix your prob, but worth a try.
Old 09-02-2010, 10:16 PM
GoodwinFord
i've already tried resetting computer and didnt work and i put a SLP loudmouth II muffler on.
I'm comsidering changing spark plugs is there any way ican take them out with out them breaking i know my year of truck's origional spark plugs are know for this
Old 09-04-2010, 04:25 AM
Djack04F150XL's Avatar
Djack04F150XL
Djack04F150XL is offline
If you have 85k your probably due the plugs anyway. Follow the TSB and have a Lisle 65600 tool kit on hand. Let the plugs soak overnight. I replaced my plugs and COPs @ 71k with Champion #7989 one piece plugs and Accel #140033 COPs. the COPs I got from Summit for about $280 for the set.
Pikachu
36
03-29-2019 02:44 PM
matts156
07-25-2014 02:16 PM
expedition2007
12-13-2013 07:12 PM
kylehoff123
10-06-2013 11:19 PM
tomanycars
07-15-2010 10:27 PM
Quick Reply: Mis Fire in Cylinder 2 and 8 Or thats what it says anyway
