No Paint Code?
Old Aug 26, 2010 | 10:35 PM
dogmantra's Avatar
dogmantra
No Paint Code?
One of the things I'd like to do this winter is touch up the paint chips in my cab. I'm not ready to do the whole exterior, but the inside is fine- aside from the chips and odd hole here and there.
I didn't suspect that this would be too tricky of a situation. I have an orange truck. It can't be difficult to match that, right? I mean, ho many shades of orange did Ford produce in 1976?
A few months ago I bought an ashtray off eBay. Seller said it was from an orange '76 (same as mine). Score! I thought. Until I put it in:
It's not the same color. Maybe the 'tray is out of a different year? The seller swears it was a '76.
So, I look at the code panel on my door and see this
The paint code info is blank. Huh?
Any suggestions on identifying the actual color I have? I've looked in a number of places and found information that often is contradictory.
Right now I only need about a 1/4 pint so I don't want to buy big and have it not even be the correct color.
Old Aug 26, 2010 | 10:48 PM
410F-100's Avatar
410F-100
in oklahoma Autozone had a machine that that did paint matching... just check out your local auto stores and see if they have a paint matcher... or try some body work shoppes, Cant be too hard to find somebody that can make up some paint for you...
Old Aug 26, 2010 | 11:00 PM
Mustang65432's Avatar
Mustang65432
I just got done repainting my interior. I brought a sample of my paint to the Napa Paint Store and they matched my paint. The only downside was the paint was a bit spendy. They also had all the books for factory ford truck paint. My paint code was blank too. I'm not sure if they ever put the paint code in these trucks.
Old Aug 26, 2010 | 11:52 PM
410F-100's Avatar
410F-100
My truck has the paint code on the door tag...
Old Aug 27, 2010 | 12:14 AM
dogmantra's Avatar
dogmantra
Yeah, that's the tag I took the picture of. It says Color Code on it and everything. Just no letter stamp.
This is a stupid sounding questions... but, how did you get a sample of the paint into the store?
Old Aug 27, 2010 | 12:36 AM
1977f250's Avatar
1977f250
I would bet your orange truck is called "chrome yellow" I had a 77 looked just like yours. May check out PPG's color chart for that year, there are two oranges. I have the Ford color chart, I just can't get to it right now.
Old Aug 27, 2010 | 01:00 AM
Mustang65432
I brought a piece of the dash in from my parts truck. Literally a piece someone pried apart the dash below the ash tray. You could take off your glovebox door if its the same color you want though.
Old Aug 27, 2010 | 09:35 AM
mikeo0o0o0's Avatar
mikeo0o0o0
One clue to your dilema could be in the DSO code. Its not the standard two digit code but six digits dso 74 + 4 digit special order code.
This truck was not a standard dealer stock order. It was special ordered by the customer. Commonly on trucks this was a fleet order and again, it was common for fleet purchasers to specify a special color (think DOT and the like).
A Marti report or Ford report might clarify this.
Another possibility is the usual shade variations between different plants using the same color code.
Old Aug 27, 2010 | 09:50 AM
Fordby4's Avatar
Fordby4
One of our paint suppliers has a special camera that will take a close up picture of what you have and match it, he will even put it into a spray can for you if you just want to touch up an area. I think it was about $50.00 bucks to do this. You may want to talk to an automotive paint supplier and check with them. Not a Checker Auto, Auto Zone or etc...
Good luck
Dan
Old Aug 27, 2010 | 11:01 AM
berry1234's Avatar
berry1234
How close to the original color did they get?
Old Aug 27, 2010 | 12:16 PM
dogmantra's Avatar
dogmantra
Originally Posted by mikeo0o0o0
...This truck was not a standard dealerCommonly on trucks this was a fleet order and again, it was common for fleet purchasers to specify a special color (think DOT and the like).
Headslap. I was hovering around that as a possibility (really hoping against it). There was a time a while back when I rolled past a DOT truck and swore it was the exact same color.
One interesting thing is that there are one or two visible runs in the paint inside the cab. Down along the kick panels. It looks like someone touched it up at some point and overdid it a bit. So, I know SOMEONE had a matching paint supply.
Old Aug 27, 2010 | 12:22 PM
dogmantra's Avatar
dogmantra
Good luck
Dan
Is that a local guy or a chain? Sounds like the first option I'll check out.
Old Aug 27, 2010 | 12:23 PM
berry1234's Avatar
berry1234
There are actually a few visible paint runs on my original paint. Could be factory.
Old Aug 27, 2010 | 12:46 PM
Fordby4's Avatar
Fordby4
dogmantra,
Not sure if it's a chain, the name is Ed's Automotive in Loveland, Colorado
Old Aug 27, 2010 | 12:55 PM
HIO Silver's Avatar
HIO Silver
Blank Paint Codes
2x with a special orders or fleet sale. The same issue comes up with 65-73 Mustangs.
The ash tray looks like international orange (like the Coast Guard colors, not as in International Harvester).
AC
dogmantra
Dec 1, 2010 08:02 PM
dogmantra
36
Oct 31, 2010 09:30 PM
dogmantra
Aug 15, 2010 04:29 PM
dogmantra
Jul 27, 2010 08:13 PM
dogmantra
May 22, 2010 11:31 AM
