Removing inner wheels on F5
Old 08-25-2010, 03:02 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
harleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to beholdharleymsn is a splendid one to behold
OK, I got my new 'non widowmaker' wheels ready to mount, but I can't get the inner rear wheels off. I thought I read somewhere that the stud ws actually an inner stud/nut combination that must be removed to get the rear wheels off. Some of these look like they go through the inner wheel and some look like they are over them. Hard to tell with all the rust. I checked the shop manual, but it is really vague on this issue.
If they are studs/nuts, will they be the same thread inside as outside?
Old 08-25-2010, 03:21 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
I believe what ya got is a bud nut and thimble nut assembly. ya got to take the thimble off that the outside wheel nuts go on. Takes what is called a thimble socket or one that is a combination socket. The thimble nut looks like a stud but it is what is holding the inner wheels on and will come off.
Old 08-25-2010, 03:50 PM
3414
3414 is offline
3414 is gaining momentum as a positive member of FTE.
Yep.
You removed the large hex head nuts (outer nuts) to remove the outer wheels. Now to remove the inner wheels you must remove the inner nuts. They have a 13/16 square head. To keep from rounding it off, only use a 4 point (square) socket. With the torque required, an 8 point or 12 point socket will just round it off.
Old 08-25-2010, 04:15 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
truckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant future
Joe - I replied to your p.m. with diagrams and pics. Stu
Old 08-25-2010, 05:44 PM
harleymsn's Avatar
harleymsn
Thanks guys, I stopped at the NAPA store and asked the guy for a thimble socket and he was totally puzzled. When I told him what it was for he said, "Oh, we always called those a 'Bud' socket." I knew then we were on the right track. They didn't have any, but it will be there in the morning for me.
Stu, thanks for the pm, I sent you a follow up.
Old 08-25-2010, 06:12 PM
truckdog62563
Joe - the inner cap nut is threaded on to the stud just as on the fronts. Keep in mind these things were put on at 500 pounds of torque, and they've been on there a lot of years. So you might need to "encourage" them to come off. Some heat, some PB Blaster, and a BFH should do the job once you've got your socket. Stu
Old 08-25-2010, 06:34 PM
harleymsn's Avatar
harleymsn
I suspect the PO ran into the same thing. All of the outer lug nuts were really free and came off with little effort. I have no delusions that the inners will be the same.
Old 08-25-2010, 06:56 PM
1952's Avatar
1952
1952 is offline
1952 is starting off with a positive reputation.
I lucked out and found a FOMOCO script Bud or thimble socket a few years ago. Will work nicely on my M-H!
They may have right and left hand threads, some trucks do.
Old 08-25-2010, 07:09 PM
truckdog62563
They will for certain be left and right hand threads. I "splained" that in our PMs. Any plans to move the M-H west, or have you done that already? Stu
Old 08-26-2010, 08:52 AM
1952's Avatar
1952
1952 is offline
I'm just waiting until I know where we'll be. Oregon is in such an economic mess, keep earning less, and less, and less.
Old 08-26-2010, 09:21 AM
truckdog62563
I hear you. Your state is like mine, controlled by the free spending types in your northern big city. At least yours don't go to jail. Sometime I'd like to hear your views on Oregon's prohibition on drivers pumping their own gas. Oregon and New Jersey, as I understand, are the only states with that law. That discussion might be best handled with PMs. Stu
Old 08-26-2010, 06:04 PM
harleymsn's Avatar
harleymsn
Picked up the socket at NAPA this morning, stopped at Lowes for a 4' x 1 1/4" pipe and headed for the wheels. The 4 foot pipe on my 3/4" breaker bar made quick work of those inner nuts. Got all the wheels changed over pretty quickly and this guy is now a happy camper.
From this
To this
Thanks for the help guys!!!
Old 08-26-2010, 06:35 PM
truckdog62563
Outstanding Joe. They look great. The white works well with the grey truck. Stu
Old 08-26-2010, 06:58 PM
harleymsn's Avatar
harleymsn
Actually it is Palisade Green.
Old 08-26-2010, 07:16 PM
1952's Avatar
1952
1952 is offline
Nice Job!!
Quick Reply: Removing inner wheels on F5
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
