What is this plug and where does it go?
Hi, The picture attached is of a plug I found under my hood while replacing a coolant hose. It isn't hooked up to anything. Should it be? I can't find its mate.
It is on a 90 F150 5.0 near the drivers side of the distributor on top of the intake. It is not the timing Jumper for the distributor, but it is near it.
Ok, not sure how to include picture.......
It is a black connector with red plastic trim with two wires coming out of it. Looks like it has two prongs it plugs into. The plug housing is male, with female inserts for prongs.
ImageShack® - Online Media Hosting
Click browse, find picture, hit upload and copy the forum code. Then paste on here.
I still don't see where to plug this in. Its only on about 6 in of wire, so it can't be far.
If someone could post a picture where it goes, that might help.
The AC works. The only wiring harness mentioned in Haynes is the clutch switch. I wouldn't think the A/C would work without this plugged in. Maybe it goes to the power steering below, hence code 52? Engine has been stalling when I have the A/C on, and apply the brake and turn wheel (like taking an exit ramp).
