My 03 F350 came with an OEM visor that had the clearance lights mounted in it. Looked kinda cool, but as it got older it squeaked etc. Had many fixes done, including a rebuild by a body shop, replacing weatherstipping etc. Squaking won. Now i have this bracket welded to the roof. Any ideas on a light bar for clearance lights that will mount to that bracket? Other ideas? Thanks.
I'm still thinking that it might be an aftermarket that Ford installed, but we'll see more once you can post up some pics. I have never seen a Ford OEM visor.
So under that visor on my truck is a bracket welded to the roof (still havent fugured the picture thing out). Part of the problem is that the brackets for the front of the visor rusted and broke. At this stage it seems better to get regular clearance lights but this is where is I need some suggestions...
