Garage door opener
Old 05-29-2014, 09:50 AM
98woody's Avatar
98woody
98woody is offline
Garage door opener
Anyone having trouble programing their door opener buttons? I cant get mine to work
Old 05-29-2014, 09:55 AM
SavageNFS's Avatar
SavageNFS
SavageNFS is offline
Received 6,959 Likes on 2,187 Posts
I had issues when I first got my truck. Despite following instructions, they still will stop working correctly about every 6 months. I reprogram them and repeat the cycle for another 6 months. My openers were installed in 2010, so they weren't brand spanking new, but they weren't old tech either. I just learned to deal with it...I've sucked too much time trying to "fix" it.
Old 05-29-2014, 10:00 AM
98woody's Avatar
98woody
98woody is offline
I cant get it to work at all, my door opener is a 2003 but both my wifes cars have no problem. Easy program and never had an.issue. My truck will not work at all
Old 05-29-2014, 10:02 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
can't get mine to work either. company came out, added an adapter to my gate. works from their remote.. not my truck..
ford dealer says if the lights light, then its working (BS, but how do you fight that!?)
Old 05-29-2014, 10:07 AM
98woody's Avatar
98woody
98woody is offline
Thats rediculous
Old 05-29-2014, 10:09 AM
goatram's Avatar
goatram
goatram is offline
I have the same issue. thought it was me being a dump a$$. I also have an issue of my radio not coming on at start up.
Old 05-29-2014, 10:14 AM
98woody's Avatar
98woody
98woody is offline
Im having the radio issue, its lite up but I have to turn it off then back on again to get sound
Old 05-29-2014, 10:38 AM
F350SD's Avatar
F350SD
F350SD is offline
That's on my list of things to do today. I will let you know how it goes.
Old 05-29-2014, 11:16 AM
F stock owner's Avatar
F stock owner
F stock owner is offline
I had to buy a conversion module from LearCar2U to get my door to work. LearCar2U - Home Apparently my door was not supported. Strange because my other half drives a 2013 C-Max Energi. All I had to do to program hers was hold the old handheld box close to the visor while holding one of the buttons down for a few seconds. With the conversion module I haven't had any problems opening the garage door from my truck since.
2012 F-350 Lariat CC FX4 LB
Old 05-29-2014, 11:29 AM
F350SD's Avatar
F350SD
F350SD is offline
Just successfully programmed both of my doors. So first, my truck has the Car2U buttons and I have about 12 year old Lift Master garage door openers. All I had to do is to press the outer 2 buttons in the truck for 1-2 seconds. All three leds turned on. Then get out and press the learn button on the garage door, then hurry back to the truck and press and hold the button I wanted to program. Hold it until the door opener lights flashed. Took about 20 seconds. The repeat for the second door.
Hope that works for you. Good luck.
Old 05-29-2014, 11:32 AM
SavageNFS's Avatar
SavageNFS
Sounds correct, but my truck forgets at least once every 6 months and I have to do it all over again...lol
Old 05-29-2014, 11:37 AM
98woody's Avatar
98woody
98woody is offline
I did that 10 times, lights flash but door no worky
Old 05-29-2014, 11:42 AM
FordService's Avatar
FordService
FordService is offline
Official Ford Rep
Hey everyone,
If you're having the same issues as 98woody, make an appointment at your dealership so a service tech can inspect. Post your results here; I'll keep checking in to see if anyone needs additional help.
Crystal
F350SD's Avatar
F350SD
F350SD is offline
One other thing. The first door I programmed while the truck was in the garage. It worked no problem. The second one was my door so I backed out of the garage. It tried it a couple of times and it didn't work so I pulled into the other bay and tried again. Then it worked. My only thought was that it needed to be closer to program. Not sure...
Old 05-29-2014, 11:47 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
mine is a property gate. I pulled the truck grill to within 1 inch of the controlbox.
the vendors remote worked from 30 ft away
Quick Reply: Garage door opener
