My '15 Platinum has the same settings. Does anyone know if Ford is working on a fix for the climate control fan speed issue after remote start? OR should I take it in and have them document this "feature"?
Yes, but the Wrangler probably won't tow 24,000 pounds.
While falling off a cliff, maybe
But I don't understand how a vehicle that goes more should not have a display system with as many options? Maybe the weight difference of the added code allows more towing...
Adjust the HVAC settings to AUTO in order to have the vehicle automatically turn on the A/C in warm temps, heat/defrost in cold temps, and whatever else is available.
My truck automatically turns on the A/C in warm temps, heat/defrost in cold temps regardless of what setting the HVAC system was on when I last shut off the vehicle.
